4” Jointer ID
GreyOwl
4” Jointer ID
Post by GreyOwl »
When we got this Mark V several years ago, one of the accessories was this jointer which we haven’t identified just who made it. Maybe someone here can help?
Charles
1981 Mark V-500
GreyOwl
Re: 4” Jointer ID
Post by GreyOwl »
It’s hard to believe that almost a thousand views and not any idea of who made it:)
Charles
1981 Mark V-500
larryhrockisland
Re: 4” Jointer ID
Post by larryhrockisland »
What does the plate on the blade guard say?
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
larryhrockisland
Re: 4” Jointer ID
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
Re: 4” Jointer ID
Charles,
It looks like Larry has solved the mystery.
Yesterday you said,
Understand not all of the views were from actual people. Bots, as I understand they are called, search the internet and they rack up a lot of the hits you see. That being said, I looked at your post when you originally posted it but had no idea what company made the Jointer. I didn't post then since I had no useful information to give.
As for the Jointer itself, it looks like someone set it up very well to work on the Mark V.
GreyOwl
Re: 4” Jointer ID
Post by GreyOwl »
The plate is just the standard warning info, nothing else.
It does seem to work very well and quite a bit of home engineering to get it to line up with the power head.
Larry: thanks for the info link. I will check it out. It’s weird that there are no tags on the unit especially for the depth of cut. They must have been adhesive labels originally.
Charles
1981 Mark V-500
larryhrockisland
Re: 4” Jointer ID
http://vintagemachinery.org/pubs/29/2796.pdf
http://vintagemachinery.org/pubs/detail.aspx?id=2796
This may be the manual or one close to it, I don’t see a year listed.
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
GreyOwl
Re: 4” Jointer ID
Post by GreyOwl »
Thanks, that looks like the correct one to me.
Charles
1981 Mark V-500
