Taking the bow out of 1/2" plywood
putttn
Post by putttn »
I've got a 3' x 3", 1/2" plywood sheet that has a bow of about 1" in the center if laid flat on a table. Is it possible to take the bow out? How would one go about doing so. I have it clamped to my table now with some Bowclamps forcing it to the table. Didn't take much pressure to push it down but wondered if it would flatten it out?
a1gutterman
Post by a1gutterman »
putttn wrote:I've got a 3' x 3", 1/2" plywood sheet that has a bow of about 1" in the center if laid flat on a table. Is it possible to take the bow out? How would one go about doing so. I have it clamped to my table now with some Bowclamps forcing it to the table. Didn't take much pressure to push it down but wondered if it would flatten it out?
That depends on how much time you have. :D
Tim
tnerb
Post by tnerb »
Try dampening it and put spacers under each end to raise it off the bench. then over bow the plywood in the opposite direction of the original bow. Leave it alone for a few days. It works for me......... Sometimes!
