Dado Table Insert
still_waters_43
Dado Table Insert
Post by still_waters_43 »
I just purchased the 6" Dado blade/cutter set from Shopsmith. I was thinking I needed a table insert for it, but I can't find one on the SS site. Also I have seen two different kind of dado inserts for sale on eBay. So, obviously I'm confused right now, can someone thelp me with this?
judaspre1982
Post by judaspre1982 »
judaspre1982
Hi,
You would be looking for a 555120 for the 505/510/520 model and the 505621 for the 500.
Ron309753
Post by Ron309753 »
Still Waters 43,
The oval shaped table inserts are for the older table system (Model 500). The inserts that are round on one end and squared off on the other end are for the newer 505, 510 and 520 table systems (Note: the 505 and 510 have the same main table, but the 505 did not come with floating tables and connector tubes).
Here is the doc link for the dado inserts:
http://www.shopsmith.com/ownersite/cata ... insert.htm
The Model 500 insert is not shown.
Hope this helps!
Sincerely,
Ron
judaspre1982
a1gutterman
Post by a1gutterman »
still_waters_43 wrote:I just purchased the 6" Dado blade/cutter set from Shopsmith. I was thinking I needed a table insert for it, but I can't find one on the SS site. Also I have seen two different kind of dado inserts for sale on eBay. So, obviously I'm confused right now, can someone thelp me with this?
Yes, you can still get a new SS dado table insert. No, you do knot need one; you can create your own inserts. :)
Tim
