Router Table
clementfeme
Router Table
Post by clementfeme »
I would like to share a picture of my router table. it is a close copy of Norm's, on the Yankee workshop. The main difference is that I built the sides and back using panel & frame construction. it cut down on weight, but did lengthen the construction time.
Thanks for viewing,
Clement Femelat
[The extension bmp has been deactivated and can no longer be displayed.]
Construction 01.jpg (162.62 KiB) Viewed 2677 times
Gene Howe
Post by Gene Howe »
Router table is a misnomer. That's a fine piece of cabinetry you are using as a router table. I'd be proud to set it in my living room.
Gene
dlbristol
very nice!!
Post by dlbristol »
Great piece of work. I'll bet it works as good as it looks.
Dave
judaspre1982
Post by judaspre1982 »
I remember that episode on NYWorkshop very well! At one time I was going to do that project. I think you did your project in Spades!
Very Nice, Clement:D !!!! Excellent Work! I'd be very proud to have an exact copy of yours, if there was room.
Thank you for showing us your project!
a1gutterman
Post by a1gutterman »
Very nice Clement! Isn't that a SS miterguage on that router table???:D
Tim
clementfeme
Router Table Follow up
Yes Tim That is a SS miter guage on the Table. The Table top is 3/4 Ply covered with a sheet of butcher block formica. I installed a miter rail down the frount. Works great. I have also made a coping sled, and it works even greater. I do use my SS 500 when I can because it is Higher, and I can pull a stool right up to the machine. You see I have had a stroke three years ago, so I am confined to a wheel chair most of the time. I can move about from one tool to another on crutches when I need to. You see, we cannot let anything get in the way of our woodworking.
Thanks for the come back Tim,
Clement Femelat
Finished #1.jpg (214.92 KiB) Viewed 2614 times
Construction of 2nd table.jpg (276.59 KiB) Viewed 2603 times
Using SS 500.jpg (481.21 KiB) Viewed 2607 times
Sliding block squair.jpg (364.49 KiB) Viewed 2602 times
a1gutterman
Thanks for the additional pictures, Clement. Glad to see that you overcame your Stroke! As for Gene...
Gene Howe wrote:Router table is a misnomer. That's a fine piece of cabinetry you are using as a router table. I'd be proud to set it in my living room.
...he must be single! TLOML wood never let me put a wood-working tool in her house!:D
Tim
a1gutterman wrote:Thanks for the additional pictures, Clement. Glad to see that you overcame your Stroke! As for Gene......he must be single! TLOML wood never let me put a wood-working tool in her house!:D
And YET she lets a 'Wood-Working Fool' in!:D
