Stop Collars
mbcabinetmaker
Stop Collars
Post by mbcabinetmaker »
I need some of the regular stop collars for the 1 1/4" tubes, and SS says Not Available.:mad: None on ebay. I need about 6. Anyone know of a suitable substitute?
Mark
2017 Power Pro Mark 7
iclark
Post by iclark »
mbcabinetmaker wrote:I need some of the regular stop collars for the 1 1/4" tubes, and SS says Not Available.:mad: None on ebay. I need about 6. Anyone know of a suitable substitute?
one possibility is the adjustable stop collar.
another would be to find some pipe with the right ID. drill and tap it, and then cut slices to make stop collars.
also, I sent you a PM with a couple other options.
Ivan
ER10 awaiting restoration
navycop
Post by navycop »
If you can find some type of 1 1/4" i.d. collar and drill a hole in it. Then tap it out for a set screw. That is basically what SS did.
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
regnar
Post by regnar »
Why do you need/ what uses the 1 1/4 stop collar. I dont have any and havent seen a need for it yet. I might be missing something here. Also sent a pm of another option.
"Sua Sponte"
mbcabinetmaker
regnar
The stop collars set the depth for any of the mounting tubes being tables and some SPT,s. I need them for setting the depth of my accessories on my new SPT benches to keep the tubes above the drawers. I am sure I can come up with a another option but would just as soon have the collars.
Mark
DAYTON 2X740 http://www.grainger.com/Grainger/wwg/pr ... Collars%2C
http://www.grainger.com/Grainger/items/2X740
johnmccrossen
Post by johnmccrossen »
Check around your area for any local industrial supply companies or nut/bolt suppliers. You can always find on-line also. Grainger industrial supply was mentioned, also McMaster-Carr, http://www.mcmaster.com/#shaft-collars/=37ykhf or many other sources. What you need should be readily available and not very expensive.
John McCrossen
Everett, Wa.
1954 Mk 5 SN 269454, 1955 Mk 5 SN 316013, 1960 Mk 5 SN 360792, 1962 Mk 5 SN 380102, Magna band saw, (2) jointers, (1) belt sander, (1) air compressor, (1) jig saw, (1) strip sander, (1) 20" scroll saw, DC 3300 dust collector, Sawsmith RAS, Craftsman table saw, 13" DeWalt planer, Triton 3 1/4 HP plunge router & table
ldh
Post by ldh »
Mark,
I use these from McMaster-Carr. A bit more expensive, but they don't mar the tubes.
ldh
6436K21 @5.69 ea.
Type
Two-Piece Clamp-On
System of Measurement
Inch
Material
Steel
Finish
Black-Oxide
Grade
Grade 12L14
Bore Size
1-1/4"
Outside Diameter
2-1/16"
Width
1/2"
Screw Size
1/4"-28
Set/Cap Screw Material
Alloy Steel
Specifications Met
Not Rated
mbcabinetmaker
Thanks for all the leads and PM's guys. I kind like the split ones from McMaster-Carr as well. I will get some on order.
Mark
mckenziedt
Post by mckenziedt »
Here in Canada I get a reasonable substitute from Princess Auto stores, $1.79ea last time I got any. They are sold as retainers for round shafting in the power transmission section along with pulleys, pillow blocks, drive hubs, etc. They are clunkier than good ones and probably should have the set screw replaced with one that won't potentially mar the tubes. Inspite of their store name, PA is somewhat equivalent to your Harbor Freight stores and farm supply stores, so HF might have them. Don
D.McKenzie
520,510,mini 500,10ER,10E,Band Saws,Jointers,Scroll Saw,Jig Saws,Belt Sanders,Strip Sander,Speed Reducer & Increaser,Pro-Planer,Mortiser,Grinding wheel,Sharpening guides,Lathe Duplicater,Biscuit Joiner,Tendon Jig,Ring Master,Oneway Chuck, Most Arbors,Bits,Blades,Chucks,Cutters,Fences,Safety Items,Sanding & Sawing Items,Shop Accessories,Spare Parts
