Oiling the Sheaves
- discordanian
Oiling the Sheaves
Having just recently purchased a used SS in good condition, I've been reading a lot. I've heard about making sure that the sheaves are oiled, but I'm not sure how to do that. Do I just open the access portal and put in some 3 in 1?
I know these are n00b questions, but I can't help it.
NO!! More to follow!!!discordanian wrote:Having just recently purchased a used SS in good condition, I've been reading a lot. I've heard about making sure that the sheaves are oiled, but I'm not sure how to do that. Do I just open the access portal and put in some 3 in 1?
dontolbert
Oiling the Sheaves
Don Tolbert
Bentonville, AR
10E - sn# R-29399 - 1950
Mark V - sn# 222659 - Dec '87
Bentonville, AR
The only thing I'll add is that SS now recommends 5/6 drops of oil. Lubee the pork chop while your in there also.
- discordanian
Why not just download it!discordanian wrote:Excellent link. Thanks much. Lots of other great info at that site as well. I've bookmarked it.
Oiling the Sheaves
Excellant idea. I always recommend that any Shopsmith information, procedures and instructions that can be downloaded be copied to your computer and to a CD or DVD for backup. Many times in the past, this information on a web site has become deleted/lost for many different reasons.JPG40504 wrote:Why not just download it!
I recommend 6-8 drops of oil in the Control Sheave in 2 steps. 3-4 drops and turn the motor on, cycle the speed control handle from FAST to SLOW and back to FAST and repeat for the next 3-4 drops of oil. I put 3-4 drops of oil in the Floating Sheave and 1-2 drops of oil on the key that is exposed on the motor shaft when doing the first oiling of the Control Sheave.
Lubing the pork chop
Beeg recommended lubing the pork chop.
Would someone remind me what the pork chop is?
What should it be lubricated with?
Thanks, Mike
Thanks, Mike
Look about 7-8 minutes in.tryinhard wrote:Beeg recommended lubing the pork chop.
Thanks, Mike
http://www.shopsmithacademy.com/SS_Arch ... enance.htm
It's item H here.
http://www.shopsmith.com/ownersite/partscat/mostfrequentlyorderedparts.htm
It's part of the speed control. I've been using beeswax from a toilet bowl ring. Some use a silicone spray.
