Frozen Jacobs Drill Chuck Repair - Disassembly, Cleaning, Inspection
The jaws and holes were not numbered on mine either. Mine was an actual 3326, not a multicraft but I cant tell any difference.
Upon reassembly, I did not make sure to put the jaws back in the same holes, but I did make sure to keep the jaws in the same position relative to each other and the chuck has performed flawlessly.
- mickyd
heathicus wrote:The jaws and holes were not numbered on mine either. Mine was an actual 3326, not a multicraft but I cant tell any difference.
Me being a stats guy, you stood a 1 in 6 chance, (16.7% probability) of assembling the 3 jaws into the correct 3 holes due purely to chance. Looks like you did it!! You lucky dog you. Next thing you know, your going to run into some once in a lifetime SWEET deal on a ShopSmith
Sunny San Diego
Sunny San Diego
- a1gutterman
mickyd wrote:Me being a stats guy, you stood a 1 in 6 chance, (16.7% probability) of assembling the 3 jaws into the correct 3 holes due purely to chance. Looks like you did it!!
I'm not a mathamagician, so can you explain the math? I was thinking I had a 1 in 3 chance. If I keep the jaws the same position relative to each other, there are only 3 possible positions. See attached crude diagrams.
Were you able to see any differences with the holes in the body or with the jaws that would require specific holes and jaws to be matched? I couldn't see anything like that on mine. The only difference was the threads or the jaws so they needed to be in the right order.
mickyd wrote:You lucky dog you. Next thing you know, your going to run into some once in a lifetime SWEET deal on a ShopSmith
- 1.jpg (6.97 KiB) Viewed 8050 times
- 2.jpg (6.88 KiB) Viewed 8044 times
- 3.jpg (6.92 KiB) Viewed 8041 times
- mickyd
[quote="heathicus"]I'm not a mathamagician, so can you explain the math? I was thinking I had a 1 in 3 chance. If I keep the jaws the same position relative to each other, there are only 3 possible positions. See attached crude diagrams.
Probability 101
Inference: "How many possible combinations are there of 3 things?"
Answer: 3 factorial = 3! = 3 x 2 x 1 = 6
Hole A, B, C
Jaw 1, 2, 3
so
A.....B.....C
1.....2.....3
1.....3.....2
2.....1.....3
2.....3.....1
3.....1.....2
3.....2.....1
You see now grasshopper?
Probability 101
Hole A, B, C
Jaw 1, 2, 3
so
A.....B.....C
1.....2.....3
1.....3.....2
2.....1.....3
2.....3.....1
3.....1.....2
3.....2.....1
Sunny San Diego
Sunny San Diego
um, Mike, I think you missed the constraint of the jaws being in the same (original) relative position.mickyd wrote:Probability 101
Hole A, B, C
Jaw 1, 2, 3
so
A.....B.....C
1.....2.....3
1.....3.....2
2.....1.....3
2.....3.....1
3.....1.....2
3.....2.....1
that reduces the possibilities to:
A.....B.....C
1.....2.....3
3.....1.....2
2.....3.....1
Ivan
ER10 awaiting restoration
AND since the holes ARE identical, the possibility of Ivan getting his assembled 'Properly' is 100% with his 'sequence/order restraint.iclark wrote:um, Mike, I think you missed the constraint of the jaws being in the same (original) relative position.
A.....B.....C
1.....2.....3
3.....1.....2
2.....3.....1
Ivan
Mike's potential number of combinations are 2 since the holes ARE identical. IF he got it wrong, he only needed to reverse the position of two of them.
123 == 231 == 312
132 == 321 == 213
ABC .... ABC .... ABC
In fairness to Mike, he was acting on info that implied the holes were unique. Thanks for the peek at your info source. I found it quite different(good) from the jacobschuck site(more history/insight to real world dealing with the repair of the chucks).
- wlhayesmfs
I just hope I don't need to take my apart, Math and I don't mix. I look at pictures.
Bill
Broken Arrow OK
Broken Arrow OK
- wlhayesmfs
- mickyd
A.....B.....C
1.....2.....3
3.....1.....2
2.....3.....1
Ivan
what about
A.....B.....C
2.....1.....3
1.....3.....2
3.....2.....1
Sunny San Diego
Sunny San Diego
