Bandsaw Question
Bandsaw Question
I just used my bandsaw for the second time (it's still new) and the rubber tire came off the bottom wheel, got it put back on and it came off again. I looked in the manual but couldn't find out what kind of glued to use to keep that from happening again.....any ideas?
- a1gutterman
When you say "new", did you buy it from SS? If so, call them and they will probably make it right. Maybe they will send you a new wheel or maybe they will send you a new tire kit or maybe they will send you glue.flyslinger wrote:I just used my bandsaw for the second time (it's still new) and the rubber tire came off the bottom wheel, got it put back on and it came off again. I looked in the manual but couldn't find out what kind of glued to use to keep that from happening again.....any ideas?
Tim
I am tring to find a belt to fit my 1985 Universal Products 3 speed band saw. The other one snaped in two. It looked like a hollow piece of tubing. I don't know if that was the original or not. I got the saw off a lady that was getting a divorce. She said to go in the shed and take whatever I wanted.
I see said the blindman, to his deaf wife, as he picked up his hammer and saw.
Shopsmith Mark V. DC3300
Jared
Jared
Bandsaw Question
The later model bandsaws I have repaired did not use any glue on either wheel. I find that any speed above 1200 RPM can pop off these tires.flyslinger wrote:I just used my bandsaw for the second time (it's still new) and the rubber tire came off the bottom wheel, got it put back on and it came off again. I looked in the manual but couldn't find out what kind of glued to use to keep that from happening again.....any ideas?
I quit using the adhesive that comes with the black tire kit (555644). I could not get it to spread evenly on the wheel with it leaving small bumps under the tire. The last few sets of black tires I installed, I used the 3M 77 spray on adhesive. I installed the tire, used a large flat blade screwdriver under the tire with the screwdriver blade sticking out behind the wheel. Then with the wheel still clamped so it would not turn, I tilted and quickly slide the screwdriver around the wheel spraying the wheel and tire area just behind the screwdriver. I did install cardboard behind the wheel to protect getting adhesive inside the bandsaw cabinet. I did this quicker than I typed this. I only glue the bottom tire as the bottom wheel only has one edge/ridge to hold the tire on the wheel. The top wheels I have done has an edge/ridge on both sides of the tire and grooves. I use a 8" brass wire brush on a buffer motor to clean the old tires off the wheels.
I have collected quite a few sets of black tires as they are all I use. I find I have various thickness, different widths and different lengths of tires. Some are almost impossible to install due to their shorter length. Had to lay them in the sun on a flat piece of cast iron for a few hours this summer to get them to stretch over the wheel. All the tires were in Shopsmith plastic bags with instructions.
