Quill Question
Quill Question
How much quill play should one expect when the quill is fully extended with a ss brad point drill bit attached?
Exactly what do you mean by 'play'?flyslinger wrote:How much quill play should one expect when the quill is fully extended with a ss brad point drill bit attached?
Let's change the description to 'in and out'(closer and further from the headstock) and side to side(right angle to 'in and out').flyslinger wrote:"Play"... in this case would be side to side, front to back, it also don't matter if there is anything is attached to the quill or not.
In and out can be due to the knurled collar not adjusted properly to limit the 'in and out' play. The collar should be snug with outward pressure applied to the quill shaft(not the feed handle).
Side to side is likely a bearing problem.
Are ya getting a loaner headstock while yours is being repaired?
