I hope that someone can help me to determine if my rip fence is deformed and how to fix it..
This is not the rip fence that came with my upgrade but it is very disappointing.
When I move a dial indicator along one side it seems reasonably true. The indicator varies from one end to the other by about .005" give or take. But when I check the other side it deviates about .012" and the readings get lower in the center and then go back up at the other end. What could cause this and how can it be fixed. It does not appear to have been dropped and if it was bent one side would not be true. I am confused. The deviations are not huge but are puzzling none the less.
520 Rip Fence
520 Rip Fence
MarkFive510
BigSky wrote:I hope that someone can help me to determine if my rip fence is deformed and how to fix it..
I seriously doubt that it is bent but the face could have gotten damaged somehow.
If it were bent, one side should be the inverse of the other.
That being the case, all I know to do is build a pseudo fence to give you the straight surface. Problem will be the weight. That fence is heavy without anything tacked on.
dusty wrote:I seriously doubt that it is bent but the face could have gotten damaged somehow.
I have not had one of these in my hands, but I assume it is an extrusion with a 'hollow' interior. If so it is probably 'warped'.
MarkV - Sounds to me that there has been a sacrificial fence attached to the fence and tightened enough to stretch the aluminum. My 510 fence has a bow (inward) in the center of a few thousandths. Still works alright!
The best advice I can give is to rip a couple of boards, then check to see if the results are straight and like you need. If so, put the dial indicator back in the drawer, until you need to check something again.
Another sacrificial fence, maybe one on each side might be your solution.
charlese wrote:MarkV - Sounds to me that there has been a sacrificial fence attached to the fence and tightened enough to stretch the aluminum. My 510 fence has a bow (inward) in the center of a few thousandths. Still works alright!
Nice try Charlese but I threw the box for the dial indicator away. That puppy stays ready for a call to duty on a moments notice.
dusty wrote:Nice try Charlese but I threw the box for the dial indicator away. That puppy stays ready for a call to duty on a moments notice.
O.K.! On call for emergency micro measurements!
That's a good thing if it fits your needs. However I suggested a drawer - not the box!
HAPPY THANKSGIVING!
520 Rip Fence
As charlese suggested, attach new "sacrificial" sides to the rip fence. If the rip fence is really bad, you may have to shim these sides to get them true to the table and parallel to the blade. It might be a lot of work up front but the effort will save your rip fence.
I've seen some done for Beismeyer fences that are like this but have a piece on the top as well. In other words, the sacrificial encases the rip fence on top and both sides.
