Has anyone purchased the shop vac attachment sold at Home Depot? The shop vac part is supposed to fit atop a five gallon bucket. If you have, is it worth the money?
BPR
"Shop vac"
I bought one and it works fine as a dry vac. I have not tried the wet vac function. Obviously, it is not meant for "large" jobs. But, for clean-up of small messes, it works. One beef I have is the exhaust port opposite the suction port. If you're vacuuming up a light material, such as sawdust, anything behind the vac will be blown all over the place before you can turn around and sweep it up. I've thought about inserting a hose or fitting to redirect the exhaust upward to avoid this problem.
For less than $25 (bucket included), I think it's a decent deal.
