Bearing Challenge
Bearing Challenge
I need some bearing help. The front bearing on my Emerson motor went bad. I have replaced it. I happened to be a std. alternator bearing. Easy job to do. I thought I would replace the rear while it was open. Wrong. The shaft is 5/8in. which in the bearing world is not common.
I called SS this am and the lady was very knowledge but since it is Emerson I was informed they are very unhelpful.
If I were to go to a bearing company with some numbers who would you suggest.
The rear bearing is OK and probably will last for a very long time but I thought I would stock one just in case.
Bob Coder
Willcox, AZ
Bob Coder
Willcox, AZ
A favorite resource on the "Old Wood Working Machines" forum is Accurate Bearing Company. I have personally dealt with them to get non-standard bearings for my 1960's Craftsman jointer. They also had a 5/8" bore. I got a pair of them with first class shipping for under $5.
You can call Accurate Bearing Company at 800-323-6548 or 630-543-2100. See if you can talk to Lynn. She works with the members of OWWM forum frequently and keeps a list of numbers of old bearings and their modern equivalents. I gave her the numbers stamped on my old bearings ("Norma XF-121-PP") and she was quickly able to cross reference that with her notes and see that the new bearing was a 6202 with 5/8" bore.
Heath
Central Louisiana
Central Louisiana
rcoder wrote:I need some bearing help. The front bearing on my Emerson motor went bad. I have replaced it. I happened to be a std. alternator bearing. Easy job to do. I thought I would replace the rear while it was open. Wrong. The shaft is 5/8in. which in the bearing world is not common.
Bob Coder
Willcox, AZ
Bob, Do you have the part numbers for the bearings that are installed?
Can you tell who the manufacturer is?
Ordered up the rear bearing from Accurate Bearing Company in IL and will be shipped from Irving, TX.
The cost is $1.95 and the shipping and handling will surely exceed that cost.
It was in stock and I should have it in a couple of days.
They have a rep. that deals only with woodwokers. A very nice touch.
Bob in Willcox
Bob in Willcox
The bearings are:
Front 6203 ... 17 x 40 x 12 mm IMHO rubber sealed is desirable(this end gets dust).
Rear 6203 ... 5/8" x 40 mm x 12 mm (same except for id) I believe the size of the start switch mechanism is what made 5/8" shaft size necessary.
It is interesting to observe the motor output shaft is 17 mm but is reduced to 5/8" for the pulleys etc. A carry over from 1950's design I assume.
In case y'all have not noticed/realized, most ALL bearings are metric, not 'inch' and inch sizes are produced for replacement purposes only and are a 'modified' metric size. The bearing numbers although slightly varying between manufacturers, are quite similar.
IMHO the dimensions/seals/clearance is the only consistent method of identifying them.
BTW Anyone needing 17 x 40 x 12 mm Double Sealed 'Electric Motor Bearing(s), PM me!
P. S. Not ALL of the motors require the 5/8" rear bearing. Most(?) have the same bearing on both ends(17x40x12mm).
