Dial Indicator Application
I don't know for sure but I do believe this approach works. I will wait until I need to realign the table to test the jig but when installed on my table now it appears to be 'right on'.
[ATTACH]7594[/ATTACH] [ATTACH]7595[/ATTACH]
[ATTACH]7596[/ATTACH] [ATTACH]7597[/ATTACH]
- P1280001 (Custom).JPG (33.26 KiB) Viewed 4627 times
- P1280002 (Custom).JPG (40.66 KiB) Viewed 4626 times
- P1280003 (Custom).JPG (32.28 KiB) Viewed 4626 times
- P1280004 (Custom).JPG (36.13 KiB) Viewed 4626 times
Awesome, Dusty. This could also be used to check the alignment of the fence, couldn't it?
Heath
Central Louisiana
Central Louisiana
heathicus wrote:Awesome, Dusty. This could also be used to check the alignment of the fence, couldn't it?
Yes, in fact it can and did. The set up that Shopsmith sells can be used the same way though and with the same degree of accuracy.
I have a fence that I bought on eBay to be used on my Crafters Station. It is bowed but only on one side. I think that I'll have to equip it with a sacrificial fence to make it completely useful.
Dial Indicator
I recently purchased a second dial indicator from Woodcraft. I thought that I had found a pretty good deal; only paid $23.95 (including tax). Then today I found this. A much better deal because it includes the tips and a magnetic base.
OK Dusty, you'd but it for less. BUT HOW MUCH for shipping?
My dial indicator set up has been calibrated and validated to my satisfaction. As a result, you can all rest well knowing that the miter tracks in your table are, in fact, parallel to one another.
My testing shows that on all three of my Mark V tables the miter tracks are within .003" of right on.
Actually, the miter tracks are likely to be even closer that that. What my testing has shown me is that my test set up is repeatable and accurate to within my self declared tolerance of .005" for all work done on/with the Mark V.
The set up I used is self explanatory.
[ATTACH]7610[/ATTACH]
PROJECT COMPLETE
Sure do wish that I had kept all of those aluminum plates that I had. They come in real handy for projects like this. They were milled to some real tight specifications for some qualification testing that I was involved with. If I had foresight, I would have handled them more like precision instruments than I have.
PROJECT COMPLETE
- P1290009 (Custom) (Custom).JPG (38.14 KiB) Viewed 4590 times
- robinson46176
dusty wrote:PROJECT COMPLETE
Good old 20-20 hindsight.
