I was wondering if anyone has tried one of these, and what kind of results did you have. The description sounds very tempting.
http://www.woodcraft.com/Product/202005 ... -Belt.aspx
Link belt on a Shopsmith?
- retiredsoldier919
David
10ER - SN:21949, Acquired 11 Jan 2010
Yep it's been tried an with good results.
I have not used one myself but Bill Mayo (billstoolz) is a strong advocate of the link belt. I would suggest you PM him with your questions.retiredsoldier919 wrote:I was wondering if anyone has tried one of these, and what kind of results did you have. The description sounds very tempting.
http://www.woodcraft.com/Product/2020051/10346/1-Foot-of-12-Link-Belt.aspx
The only drawback I am aware of is that they create pulley wear faster than 'normal' belts.
- shipwright
Mine works fine (from HF) but at the very lowest low speed it starts to touch the headstock casting causing a little whine and you have to go back up a little. That only means I'm missing out on a bit that's below SLOW anyway with the changer set correctly.
Paul M
Paul M
- retiredsoldier919
