Need Ideas
- sambofl
Need Ideas
I just recently reorganized my shop and received my fathers 1955 SS. I do have a thread on it on the General Forum under restoring 55 shop smith and the inserted picture is one from that thread. The question I have is if you open the picture attached you will see a part circled. Its pretty clear what I'm asking by seeing it and I have a couple ideas how to fix it but I figured I would ask the more knowledgable masses for maybe a different angle of approach. I was mainly thinking just building a small platform for the table saw and the other table cause I raised everything to the minimum height of the SS saw table. I don't want to get rid of the other saw cause it was a gift from my wife and don't want to hurt her feelings. So I will still use it from time to time so I'm using it as extra table space for cutting 4x8 sheets. Plus I'm military so I have to be able to break it down to move or god forbid store. So a perm. fix is not a option. Any ideas??
- Bronze Member
Why not use the tools you have and cut some properly sized hardwood strips that you have slotted in two separate lengths at least the length you need for extention and drill the metal legs, insert a through bolt in the metal legs, through the slotted hardwood strips then a couple fender washers and wingnuts to tighten the leg extentions and use as levelers too!
Salmonslugger
Neah Bay, WA
- a1gutterman
Ideas
Salmonslugger has a great idea. Another one would be to aquire a Universal Mobile Mount (sold by SS and others) and put the apropriate blocks between your legs and the Universal Mobile Mount. That would allow you to move it around without always adjusting your blocks. As for the work bench, I think that you could permanatly alter the legs for your desired height.
Tim
Need Ideas
You could:
1. Give it to me. It's about the right height without those wood blocks.
2. List it on ebay. Buy another Shopsmith with the proceeds.
3. Use salmonslugger's fix. Only use steel angle iron, predrilled/slotted.
(I have some you can have - it was adjustable/breakdown shelving)
4. I like a1gutterman's fix. Universal Modil Mount w/locking wheels.
leveling idea
All of the ideas presented are good and will work, but personally I would raise the saw rather than raise the table. I think four stable legs on the ground would be better and provide greater safety. I would build a platform the same size as the footprint of the saw and add a plywood top to the platform that you could secure the saw with bolts, of possible. If not possible, build the platform with sides or cleats that encompasses the base of the saw so it won't move. Secondly, secure the platform to the top of the base. The challanging part might be the measurements necessary to make the platform the right height to match up with the ss.
Good luck
Good luck
