Lathe Dancers - Do they Work?
It has been since February and July of 2008 since we talked about lathe dancers. I had it my mind they would serve as a poor man's lathe duplicator. Do a forum search for Lathe Dancers and you will see the two posts from back then (2008).
Well - I finally got a round TUIT and an hour or so per day for the last few weeks did some construction and tried them out.
Didn't have any turning project in mind - just wanted to see if the dancers worked. So I drew out a template of what could be a pair of leg stretchers for a chair or bench. The Idea of dancers was an old method of duplicating spindles way back when turners didn't have better automation. Would this work on a Shopsmith lathe?? We will see!
Here's some photos - It will take several posts to cover the story -
THE DANCER SUPPORTS
[ATTACH]8910[/ATTACH]
THE SUPPORT WITH HOLDERS (used scrap material
[ATTACH]8912[/ATTACH]
SHOWING ATTACHMENT BLOCKS FOR SHOPSMITH these are from ripped 2X6s
[ATTACH]8913[/ATTACH]
DANCER BLOCKS Hard maple 1"x1/2"x1/4" - 1/8" holes and 1/4" single hole - screw hole tapped, then "crazy glued" then re-tapped
[ATTACH]8914[/ATTACH]
SINGLE BLOCK WITH DANCER dancer is a bamboo skewer - plastic Pick-Up-Sticks would also work
[ATTACH]8915[/ATTACH]
TO BE CONTINUED ---
MOUNTS SET UP ON LATHE (photo taken after turning so shows all the chips)
[ATTACH]8916[/ATTACH]
TEMPLATE MOUNTED ON STORY BOARD WITH DANCERS SET TO SIZE
[ATTACH]8917[/ATTACH]
NEXT THREE PICS SHOWING DANCERS IN USE (the lathe was turning when these pics were snapped When diameter is reached, the dancer quits dancing and bows deeply. This is why some of the dancers seem upside down
[ATTACH]8918[/ATTACH]
CLOSEUP OF THE THREE LEFT DANCERS
[ATTACH]8919[/ATTACH]
[ATTACH]8920[/ATTACH]
TO BE CONTINUED ----
The rest of the picture story - - -
THE DANCER JIG WORKED!!! NOW????? WHERE DO I NEED SPINDLES?
[ATTACH]8921[/ATTACH]
--END-- Whoops! forgot some stuff - see post #13--
nuhobby
Post by nuhobby »
Chuck, that is really cool!
Chris
easterngray
Post by easterngray »
Fantastic! Nicely done - those are really terriffic
beeg
Post by beeg »
GREAT presentation there Chuck.
a1gutterman
Post by a1gutterman »
Very nice work you did Chuck! You are a true craftsman.
Tim
dewey2me1mothyme
Post by dewey2me1mothyme »
This is a very interesting thread, and Kudos on a job well done. I need to come back and read it all again when my one active brain cell is more alert, I'm sure I missed some important stuff. Alot to grasp in here.
Anything worth dewing, is worth dewing well!
I'm dewing my thyme in southwest Indiana
fiatben
wow
Post by fiatben »
That is a very neat solution. I like that it still requires skill on the part of the turner while solving the problem with repeatability. Thanks for the demo!!
efmaron
Post by efmaron »
Way to go Chuck, brilliant idea
Eric, Sebring Fl.
