I've attached a doc file with some (very simple) drawings showing the setups that I envision with the requirement that I be able to use the jointer at the same time as the table.
Setup A:
- Headstock pushed all the way to the left to drive jointer
- Short extension tubes to left of main table (supported by telescoping legs positioned just inside the jointer) using one floating table
- Short extension tubes to the right, between main table and extension table using the other floating table
Setup B:
- Similar to A, except uses 5' tubes instead of two pairs of short tubes.
Setup C:
- Similar to A, except uses 5' tubes to right of main table supported by telescoping legs.
- Requires an extra set of legs if I want to retain left side support.
Setup D:
- Same as C except uses extension table for mid span support
- Requires both an extra floating table and extra set of legs
Setup E:
- Short tubes between main table and extension table using one floater.
- Short tubes between extension table and legs using one floater.
So, is the only real advantage I get with 5' tubes a greater than 32" capacity? If so, how often do you really use this larger capacity? And when you do, would you still like left side table support? Seems like anything that big will also require both infeed and outfeed support as well.
I usually just use a circular saw to rough cut panels to size before they get to the table saw. I can't really see then why I would need the greater capacity. So, are the 5' tubes valuable for a more rigid/stable/better aligned setup?
Thoughts?
Brian
