Pen turning
jltrice
Pen turning
Post by jltrice »
I have a Shopsmith 510. I have not used the lathe yet. I am interested in turning some small things, pens, bottle stoppers, etc. Can I do it on my Shopsmith? I only have the spur drive center. Are there options for driving from a MT2 arbor? It also appears that the tool rest cannot be placed close enough for these small items???
Any insights to this type of turning would be appreciated.
RobertTaylor
pen turning on a shopsmith
Post by RobertTaylor »
shopsmith no longer sells a pen mandrel. however pennstate industries has two that will work. one has a 5/8" bore that will mount directly on the spindle, the other is a straight replacement shaft that can be held in your drill chuck or the 1/4" router chuck if you have one. i reccomend the 5/8" bore to 1"x8tpi spindle adapter so that you can use most commonly available lathe accessories on your shopsmith. feel free to ask any specific questions you may have. i have turned about 250 pens on my shopsmith so you may know that the standard shopsmith toolrest works very well.
jltrice
Post by jltrice »
Thank you for your quick response and forgive my lack of experience here. I looked up the spindle adapter you recommended but I still do not see how that will help me with pen turning. What are you putting on the drive end? An arbor?
Once I over come this one, I will tackle the tool rest. My standard tool rest doesn't seem to be able to be positioned for pen turning.
dasgud
Post by dasgud »
Hi jltrice,
When I called PSI to buy a starter pen set-up I told them I will be turning on a Shopsmith and they knew exactly what to send to me. It was exactly what I needed too.
Their customer service was really good and they know about SS.
joedw00
Post by joedw00 »
jltrice
Welcome to the Forum. I just started turning pens. This Basic Pen Making Starter Set w/ 5/8 Mandrel is for shopsmith. And Here is just the Mandrel.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
wa2crk
Post by wa2crk »
JLTrice
The morse #2 taper can be removed from the mandrel shaft and the shaft can then be used with the SS drill chuck. It is difficult to turn some pens with the SS tool rest because ther standard tool rest will not fit between the drill chuck and the tail stock. When the barrel of the pen is turned the lathe tool will sometimes be too far from the work and may cause a chatter. Try to get the SS shorter tool rest to get in closer. If you have a lift assist installed then the tool rest carriage can not be moved far enough to the right and you may find that the lathe tool will fall off the right end of the tool rest. This may ruin your project. In my case I use #2 Morse taper extension available from Grizzly Industries for about $10.00. This has the effect of moving the turning about 4" to the left to give enough room for the tool rest.
hdtran
Post by hdtran »
jltrice wrote:I have a Shopsmith 510. I have not used the lathe yet. I am interested in turning some small things, pens, bottle stoppers, etc. Can I do it on my Shopsmith? I only have the spur drive center. Are there options for driving from a MT2 arbor? It also appears that the tool rest cannot be placed close enough for these small items???
Yes, you can. You need to get a pen mandrel, as others have suggested, Penn State Industries, model PKM-CL. I personally like using a live center on the tailstock]http://picasaweb.google.com/hy.d.tran/Pens#[/url]
Regards,
hdt
fiatben
been there, done that
Post by fiatben »
I first started making pens (and pencils) about 15 years ago and all I had was a SS. It's been so long ago I don't even remember the details. I eventually got so enthused with small turnings that I bought a mini-lathe, but I doubt that my results on it were any better. No advice; everyone else has it covered and are much more recent than I am, having not turned a pen in about 10 years (life got in the way of woodworking, and I hate it when that happens!).
RobertTaylor
shopsmith toolrest
in this pic you can see the shopsmith toolrest.
IMG_7028 (Small).JPG (48.16 KiB) Viewed 14953 times
terrydowning
Post by terrydowning »
Don't forget the live center.
Or you could also try the "Mandrel Saver" from Penn State
I got one for Christmas and it works as advertised.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
