Checking RPM
- tomsalwasser
Checking RPM
Greetings woodworkers,
I just bought a power station off ebay. It seems to be in good shape. Any ideas on how I could check the rpms? There's a $20 tachometer on Amazon that has gotten good reviews. Thanks for your thoughts.
Best,
Tom
Best,
Tom
If you're interested in that tach, you might want this one for only $7.77, but you'll need to supply your own 9V battery. http://www.amazon.com/Digital-Photo-Las ... B001N4QY66
Art in Western Pennsylvania
- tomsalwasser
No, I haven't used it. I just ordered one after seeing you reference to a tach. I've been thinking about one for a while, and for $7.77 I figure I can't lose much. All you need to make them work is something reflective, so I figure some reflective tape from Home Depot or the like is all that's needed.
tomsalwasser wrote:Greetings woodworkers,
Best,
Tom
Question is, why does it need checking. There is no way to 'adjust' it other than the control handle. There are no internal adjustments other than motor belt tension.
P.S. I just ordered one also - comes from vxb bearings.
P.P.S. InterestingEnter tach in search field.
It gets even better than the 7.77 plus 5.99 shipping from VXB. Here you can get it on Ebay directly from China for 2.19 plus 8.77 shipping for a total of $10.96 == http://cgi.ebay.com/Digital-Laser-Photo ... 5639wt_908
And the srp is 59.95?:rolleyes:pennview wrote:It gets even better than the 7.77 plus 5.99 shipping from VXB. Here you can get it on Ebay directly from China for 2.19 plus 8.77 shipping for a total of $10.96 == http://cgi.ebay.com/Digital-Laser-Photo-Tachometer-Non-Contact-RPM-Tach-/390280381302?pt=LH_DefaultDomain_0&hash=item5ade860376#ht_5639wt_908
- tomsalwasser
JPG, I'm just curious what rpm range I'm getting from this newly acquired (ebay) power station. As I run through the speed dial, it seems like the rpms change very little from the low end to the high end.JPG40504 wrote:Question is, why does it need checking. There is no way to 'adjust' it other than the control handle. There are no internal adjustments other than motor belt tension.
[/URL]Enter tach in search field.
Tom
You might want to wait for JPG to bless these numbers before you bank on them but the advertised speed range for the power station is from 850 rpm to 3850rpm.
1.....850
2.....1050
3.....1200
4.....1450
5.....1810
6.....2200
7.....2650
8.....3220
9.....3850
Belt tension and the condition of the two belts are about the only things that could effect this operating range. I suppose the bearings could be dragging down the speed but without a tachometer I don't believe you would notice that.
Have you pulled the cover off the power station so that you can watch the variator at work while you change the speed dial.
[ATTACH]12396[/ATTACH]
High Speed
[ATTACH]12397[/ATTACH]
Low Speed
This shot shows the relationship of the Speed dial and pulleys. Don't be confused by the switch and wiring. This shot is of the Crafter's Station.
1.....850
2.....1050
3.....1200
4.....1450
5.....1810
6.....2200
7.....2650
8.....3220
9.....3850
High Speed
Low Speed
- High Speed.JPG (150.15 KiB) Viewed 5641 times
- Low Speed.JPG (159.71 KiB) Viewed 5644 times
- Belt at Near High Speed.JPG (149.29 KiB) Viewed 5347 times
