Casters for standalone scroll saw?
damagi
Post by damagi »
Just curious what people have done to put casters on their standalone scroll saw. I have extra sets of casters for the Mark V, but they are both too narrow and don't seem like they would work given the adjustable feet of the scroll saw.
damagi AT gmail DOT com
claimdude
Post by claimdude »
damagi wrote:Just curious what people have done to put casters on their standalone scroll saw. I have extra sets of casters for the Mark V, but they are both too narrow and don't seem like they would work given the adjustable feet of the scroll saw.
I think the casters are the same except for use on the SPTs there are spacers available that make the short casters fit. The castrers on my powerstaion are Mk V casters with two (1 on either side) 1/2" to 3/4" (not sure of exact measurement) spacers.
Jack
Unique! I see brackets. Different length(width)?
http://www.shopsmith.com/ownersite/itemfind.htm?item=555457&Submit=Find+Item
claimdude wrote:I think the casters are the same except for use on the SPTs there are spacers available that make the short casters fit. The castrers on my powerstaion are Mk V casters with two (1 on either side) 1/2" to 3/4" (not sure of exact measurement) spacers.
Jack
9/16"....... UH ER I THAT IS UH MAKE THAT 7/16" <<<<<<<<edit!!!!!
RonKlein
Post by RonKlein »
The casters will work just fine. You need appropriate size bolts, nuts, and washers, along with some spacers. I'm sure ShopSmith will sell you the appropriate hardware kit, or make up your own. I can probably take a look at mine, tomorrow, and give you some sizes, if you want.
Ron--K6VPV
510, upgraded to 520, now PowerPro, bandsaw, jointer, belt sander, jointmatic, scroll saw, strip sander, pro planer, OPR, DC3300, and more.
SDSSmith
Post by SDSSmith »
My scroll saw has brackets to adapt the casters to it.
Rob in San Diego
damagi
Post by damagi »
RonKlein wrote:The casters will work just fine. You need appropriate size bolts, nuts, and washers, along with some spacers. I'm sure ShopSmith will sell you the appropriate hardware kit, or make up your own. I can probably take a look at mine, tomorrow, and give you some sizes, if you want.
Please do take a look (and post photos as well if its not too much trouble).
I am also reading this thread, which seems to have some good info.
http://www.shopsmith.net/forums/showthr ... ht=casters
Note: Post #4 corrected!!!!:o
RonKlein
Post by RonKlein »
[quote="damagi"]Please do take a look (and post photos as well if its not too much trouble).
Well now, I am confused (not unusual). If I go to the ShopSmith site, Accessory Catalog, Scroll Saw, then click on casters under Scroll Saw Accesories, I see an illustration of the hardware I described (PN 555457).
If I just search on PN 555457, I see an illustration of the hardware described by jpg in post #3. This is the hardware I actually have on mine. The brackets are 1/8" thick, and about 2 1/2" across the top. There are 3/16" spacers between the brackets and legs. Ron
[ATTACH]13205[/ATTACH]
[ATTACH]13206[/ATTACH]
Ron--K6VPV
SDSSmith
Post by SDSSmith »
RonKlein wrote:
damagi wrote:Please do take a look (and post photos as well if its not too much trouble).
My caster setup is just like yours, Ron.
Rob in San Diego
