MT2 socket
MT2 socket
This is interesting, but getting a 5/8" hole bored would be a problem(it is hardened).
[ATTACH]15191[/ATTACH]
Now if anyone knows of a 5/8" to 1" sleeve adapter . . .
2mt sleeve.jpg (202.74 KiB) Viewed 1395 times
pennview
Post by pennview »
JPG, they're not that hard. You can easily score one with a file, so I'm sure a machinist could bore a 5/8" hole so you could mount it on a Shopsmith, if that's what you'd want to do. Also, these sockets are less expensive at Enco.
Art in Western Pennsylvania
pennview wrote:JPG, they're not that hard. You can easily score one with a file, so I'm sure a machinist could bore a 5/8" hole so you could mount it on a Shopsmith, if that's what you'd want to do. Also, these sockets are less expensive at Enco.
And a 'few' other things!:cool: I would guess case hardening(thin). The length(prone to wobble) could be a problem.
I have no need, but the subject was raised in another thread.
P. S. Second thoughts - I think it would be better if a larger diameter sleeve(at least 2") were bored to 1" on one end and 5/8" on the other. A 4" length would provide stability. The 5/8" bore only need to be the length of the ss spindle, and the 1" clear through to the opposite end. The tang(drift) hole would be a good idea!
pennview
Post by pennview »
I think the simplest solution to all of this Morse Taper stuff is to buy a Smithy SuperShop (or one of the originals made by Fox). It has an R8 spindle hole so you can mount anything on it that you can mount on a Bridgeport. Plus it has a threaded nose on the spindle for 2 1/4" x 8TPI accessories like big metal lathe chucks and faceplates. For using #2 or #3 morse taper items, you simply buy the appropriate R8 adapter to accept the taper. And it's got a DC variable speed motor running from 32 to 7200 RPM. And, if you take a piece of 5/8" drill rod you can fashion a spindle similar to the Shopsmith with a tapered flat and mount all of the Shopsmith spindle accessories on it using an 5/8" R8 collet.
pennview wrote:I think the simplest solution to all of this Morse Taper stuff is to buy a Smithy SuperShop (or one of the originals made by Fox). It has an R8 spindle hole so you can mount anything on it that you can mount on a Bridgeport. Plus it has a threaded nose on the spindle for 2 1/4" x 8TPI accessories like bit metal lathe chucks and faceplates. For using #2 or #3 morse taper items, you simply buy the appropriate R8 adapter to accept the taper. And it's got a DC variable speed motor running from 32 to 7200 RPM. And, if you take a piece of 5/8" drill rod you can fashion a spindle similar to the Shopsmith with a tapered flat and mount all of the Shopsmith spindle accessories on it using an 5/8" R8 collet.
If ya gonna go to all that effort, why not just get a Bridgeport!?:D They be easier to 'find' anyway!:rolleyes:
pennview
Post by pennview »
Well you can't saw or turn wood on a Bridgeport very well and they don't come with casters.
pennview wrote:Well you can't saw or turn wood on a Bridgeport very well and they don't come with casters.
Touche!:cool: You seen a Smithy Super Shop with castors?:confused:
pennview
Post by pennview »
No, I don't have an overcoat for mine.
pennview wrote:No, I don't have an overcoat for mine.
My bad!:o I misread yer caster reference(missed the "don't").
