table saw blade
table saw blade
I can't seem to get the table saw blade to stop wobbling. Any advice?
- chiroindixon
Okay.....
Grab the blade.....(while SS is "Off" of course), and work to determine where the "wobble" is from. I've encountered this several times.
Sometimes, my abor was loose on the outboard shaft. According to "Jan" at SS, replace the set screw. They get worn down and loose the roughed up "grabbing edge". I put in another. You might consider roughing up the edge if you don't have another.
Is your arbor tightened down on the blade itself? I've had a problem from time to time when an arbor loosened. Can't explain how it happens, but it did.
Finally, is your blade flat and true? If it's "wobbling", it could be bent. If a good blade, take to a pro and have flattened and sharpened. If a cheapy, chuck it away and buy a decent or better blade.
- Bronze Member
marinegunny
Saw blade..wobbing on you..Take a look at the Arbor, check to be sure you have it install correct.cmaze wrote:I can't seem to get the table saw blade to stop wobbling. Any advice?
I would like to tell you a story, a True story about a Saw Blade.
Today I just order my 1st Saw Blade for my Shopsmith. Oh I forgot to tell you. I brought my Shopsmith Mark V in 1975. Yes, that is wright in 1975. The saw blade is over 30 years old and I still use the blade. I have had no problems with my Mark V. It still run like a new, never be over haul by anyone.
Thank you for your time, I hope this information helps you in youe sawing problem. MERRY CHRISTMAS and HAPPY NEW YEAR...... John
John,marinegunny wrote:Saw blade..wobbing on you..Take a look at the Arbor, check to be sure you have it install correct.
Congrats on your success with your SS. Unfortunately, not everyone can say that.
Bruce
Wobbling Saw Blade
You didn't say whether you were using a SS arbor or the 5/8", but I discovered that if you are using the SS arbor, you have to be certain that the blade is seated on the arbor correctly before you tighten the nut. You can install the blade wrong, sort of like cross threading it!
