When I tried to login a minute ago, I got a message telling me I'm banned here and my IP is blocked. No warning, no nothing...just banned.
But then I switched my VPN server, came back, and logged in again with no problem. Strange. I thought maybe it's because this thread is more about my boat than my ShopSmith, but I make it a point to highlight the machine every time I use it to do something no other tool of mine can do. I even had a reader of my blog comment that he bought one specifically because of my high praise. I hope I don't get banned. But if I stop posting all the sudden, that's probably why.
Anyway, while awaiting a new seacock to replace the one that leaked on Splash Day (sorta), I started digging into what's turned out to be another challenging problem from splash day: my starboard engine won't start!
I'd test fired it without an impeller in the yard a half-dozen times. On splash day, it started and ran great on the second crank. Perfect idle, good pressures, and when the Travelift operator yelled out "GOOD WATER," I knew the raw water was flowing out the exhaust the way it should. And then the engine died, which triggered the low oil pressure alarm. I hit the key, heard the starter try to engage, but it wasn't turning the engine over. Tried it again...and one more time. The engine seemed stuck.
I had a video camera rolling in the ER when I lit off the engine, so you can see exactly what happened. It's at the linked article, along with a video of Splash Day, when they had to use a big forklift to pull the Travelift out of the soft gravel. For some reason, my videos don't display here.
On the engine:
It bars over normally when I put a wrench on the alternator pulley nut, so it's not hydrolocked or catastrophically busted (probably).
Electrical connections are tight.
I checked the aftercooler and muffler--the former is dry inside and the latter has ~3" of water in it, so there's no way raw water got into the engine.
It can't be a fuel problem, because the starter engages but won't roll the engine over.
I'm stumped. Thoughts?
1969 Chris Craft Roamer 46 Refit: Splash Day Breakdown
Cheers,
Q
Only 3" of raw water in the muffler
