snoopy55 wroteLast October I purchased a second 10ER (w/speedchanger) and a separate complete headstock. The springs in both headstocks had the ends broke off and need repair.
I found this thread and the repairs call for drilling the new holes. I tried this a bit after I got them, but I could barely scratch the surface!
Is there some special type drill bit to use?
My newest Shopsmith is set up as a lathe only..... New fun!!
It has been many years since I drilled new holes in mine, but I don't recall it being that difficult. :)
Things to try-
- Sharp bits
- Use a center punch to position the holes,
- try drilling small pilot holes.
Note the 10ER spring mounts on the front of the headstock, the mark V spring is on the rear. so if you watch a Mk V video, the spring winds in the opposite direction.
Good video on removing and replacing the 10ER spring.
