snoopy you said
Now, the second one has an 'S' shape to the pin end.
That should not be there. I would refer you back to my post on page 4 with the picture of a spring. The only curve shape it should have, other than being a coil, is the "hook" end where it holds on to the housing. If the pin end is "S" shaped it could cause a problem with it holding on the pin and/or staying there.
