chapmanruss wrote
In the last post you mentioned
clean/repack the bearings if y’all think I should
There are two sets of 2 bearings. 2 for the Drive Sleeve and 2 for the Quill. All are sealed bearings so if they are bad they need to be replaced.
I cannot feel or hear any problems with the bearings yet, but haven’t tried spinning it with the motor...
I’m located in College Station, TX, btw...
I got a pulley from a guy that told me it was the headstock pulley, but...1) it doesn’t fit on the headstock drive shaft and 2) it’s keyed. I believe you told me before that only the motor pulley is keyed, correct?
Made more progress today and am now completely worn out...lol
1. Got motor to the shop for rewiring
2. Got headstock off the ways
3. Got the carriage off the ways
4. Got the ways off the baseplate
5. Got the tie bar removed and brass wire brushed
6. Got the rods out of the carriage — took ***forever*** because one rod had apparently been beaten on before because the very edge was just proud of the hole it was in, so I had to file the edges down (bit of a chamfer) to get the rod out...the short rod was a PITA as well, but it’s out now. What size exactly should these rods be? I think I will be ordering new ones as these are quite soft and have gouges in them
7. Got the heavy aluminum table cleaned and getting that back together to receive the pivot / baseplate and headrest
Whew!!!!! I’m beat...it was 85F here today...still 82F now at 17:45...
