chapmanruss wrote
garyshell,
You said
With the motor running, the link belt expands a bit to the point that it rubs on the two feet of the eccentric tube mounting base.
Sorry I don't have any direct experience with a power stand. In the picture you posted it shows the hole in the top of the stand being about the same width as the space between the "feet" of the SPT stand. Is this the same on your Power Stand? If so, turning the SPT Stand around will not gain any additional belt clearance. The problem now appears to be the link belt and how it is constructed requiring additional clearance which could be corrected with a conventional V belt. One thing I didn't mention before but there has been a lot of discussion now is pulley diameters. Certainly, smaller pulleys would narrow the needed opening they pass through and still achieve the correct speed. Right now, the most inexpensive change would be to a conventional V belt.
I don't have the official "Power stand". I have a similar stand that has a more open frame, so the only impediments for the link belt expansion are the "feet" of the eccentric tube base. I'm going to try turning the base around, taking into consideration someone else's (@Majones1) suggestion that the large feet might be on the pulley side to provide support for the downward force of the belt on the pulley.
If that doesn't work I will just go with a standard V belt. The link belts do help reduce vibration but the jointer has so much mass I am not sure the benefits are that pronounced.
