JACOBEIS wrote
I have gotten it to work for about 30 seconds by taking off the belt opening the motor Sheaves with my hand putting a small piece of wood to keep it separated closing the upper Sheaves putting the belt back on the motor took out the wood and turned it on.
then it ran for about 30 seconds before the motor Sheaves began to close and the circuit trips
Something here is abnormal. The sheaves should have closed to contact the belt as soon as you took out the wood block. Then they should not have moved again except in response to a speed change. If it is not closing to contact the belt as soon as you remove the wood block that is most likely excessive friction between motor shaft and floating sheave. If lubrication didn't solve it, I would remove the sheaves and clean/polish the motor shaft and clean bore inside floating sheave. Inspect everything. Reassemble and lubricate shaft. If it is closing to contact the belt then moving more 30 seconds later, is the control sheave on the idler shaft moving, either in response to a speed change or on its own?
As some one asked I don not have it on a GFCI it wired straight thru to my Electrical Panel with a 20 Amp Breaker I even bought a new breaker as I heard if a breaker trips too often you have to change it.
And as for my Electrical Cord it in good condition, and with no belt on my motor it runs for ever and is very quiet.
I have been using 3 in 1 oil to oil all shafts and any hole and the bearings.
what would changing the Motor bearings have to do with the Motor Sheaves separating. When the Motor Sheaves close the belt riding over the top of the Sheaves but JUST A TOUCH
Belt position you are reporting is in relation to Idler or Motor sheaves, just to be clear?
What is the first thing I should change the Belt, or the Motor Bearings or the bearings on the upper Poly V belt, any other suggestion?
With the motor turned off but belts on, can you turn the headstock by hand using only the knurled knob on the quill spindle? Is it quiet when you do so? This is an attempt to rule mechanical resistance in or out as a contributor or cause.
I would like to thank all of you for your suggestions.
What age and version is your machine, and how long have you had it? Mostly I'm just wondering 3/4 HP or 1-1/8 HP motor, but others may be wondering for other reasons and this is just good to know for background.
Unfortunately, a problem like this can be caused by excessive mechanical resistance, excessive electrical resistance, the motor itself, or outside factors. Mechanical resistance seems to me to be the easiest to eliminate or confirm, though its still subjective.
