mmorris wroteThe Franklin motor that is in my 54 greenie has a 5/8" shaft and the bearings are 1 3/8" OD. The only markings on the bearings that I can see is "502-16 and ND". Does anyone have a number for these?
I mistakenly ordered 6203ZZ (I saw "Franklin motor" on the bearing numbers posted in this thread, but didn't notice that it was for a 3/4 inch shaft).
The '3/4' refers to the horse power of the motor, not the shaft size.
If they appear to be 1 3/8" od, they are 35mm od. Most motor bearings are 40 mm(1.575") with either 5/8" id or 17mm id. The 6203 should be the correct one unless the id is 5/8".
You need to measure the shaft at the bearing mount location.
