Went to press my new 6202 quill bearing on today during break time at work and ........... no go.
Came to discover that standard 6202 size is 15mm ID x 35mm OD x 11mm WD of which the OD and WD are fine, but the bore at 15mm (.590) is way to small to press on to a 5/8" (.625) shaft.
The original bearing off my 1957 greenie was a NDH marked item. That bearing measured .625 ID x 1.375 OD x .346 width with metal side shields and I am positive it was original to the unit.
I had found the new quill and drive shaft bearings from
http://www.qualitybearingsbeltsandchain.com I also feel strongly about getting the newer technology flexible side seals versus the steel shields because they provide a minimal seal against sawdust. The quill bearing I ordered was 6202-2RS C3 and as mentioned, it will NOT fit .......... be aware of this !!!!
You must order (no matter which seal style you choose) the 6202-5/8 size in order to get the proper ID that will fit onto the 5/8 shaft.
For my personal headstock rebuilds I am using the 99502 bearing from them that has the 5/8 ID, 1-3/8 OD, and .433 width but also has synthetic grease packing with the flexible side seals. This greenie headstock retains the original 3/4 HP motor with gilmer style drive and will always run at lower speeds because it powers a totally rebuilt MAGNA (greenie) band saw and on the headstock front end is the 12" sanding disk with greenie saw table - both running at the same time.
I would not recommend the rubber side seals for continuous high speed applications, but for typical woodworking from low to saw speed at basic amounts of time they are way better than the metal shielded bearings IMHO.
Time will tell for sure - am about to start on total rebuild of my main shopsmith, which is a 1962 goldie (1-1/8 HP) and will be redone with color matching 510 upgrades and 520 fence system. This unit will be sawing on a regular basis ........... all of my routing & shaping is done on a shopsmith stand-alone router table with pin-router arm attachment so the super higher speeds do not really apply in my case.
