edma194
I'm am largely out of action again, this time because of a spinal stenosis. So I have time on my hands and I started looking into how DC motors from treadmills have been used on various machines, many lathes especially. I saw a Youtube about a guy who put some kind of DC motor in a Shopsmith, and it appeared to completely replace the original motor and mechanical speed controller. There weren't many details though.
Read on if this subject interests you. I'll provide a summary of my thoughts and if anyone is interested I'll flesh it out.
So, replacing the motor in a Shopsmith headstock with a treadmill motor. It would need an adapter/coupler to provide a 5/8" shaft for the fan sheave and spring. The motor would be a little smaller than Shopsmith motors, but probably wouldn't leave enough room for a variable DC power supply in the motor area, and that supply would produce a lot of excess heat. I think the power supply and motor controller should be in an external control panel box connected to the headstock where the power switch is. The control panel would have an on/off switch, forward/reverse switch, spindle RPM display, and a dial control for the motor speed, maybe a motor RPM display.
So what does that create? The DC motor has a top speed in excess of 6000RPM at full power. With the Shopsmith speed controller at the fasted setting the spindle speed could be over 9000RPM. However, when the motor is running at full speed the slowest speed could be higher than 1300RPM. To get slower the motor has to be slowed down, that's what the dial control for the motor speed is for. The motor can slow down a lot, to 60RPM or less. The catch is that the motor is slowed by reducing power to it. There are practical limits to how slow the spindle can get and still produce useful torgue.
These motors are typically rated at 2.5HP. Might as well throw that number out the window. When loaded it might produce half that, or 1.25HP which is still better than the Shopsmith 1 1/8. The motors usually have a large flywheel that improves their performance characteristics, and the Shopsmith speed changer improves torque at lower speeds. Reducing voltage reduces motor speed and power together. At half speed you might only have performance comparable to a 3/4HP motor. Half motor speed is something over 3000 RPM, very similar to the standard AC motors, and the power available in the oldest Shopsmiths. I use a Greenie for years and it's 3/4 HP motor was just fine in most cases. At half motor speed, Slow on the speed dial will be around the same as the standard Shopsmith. You can keep reducing motor speed and spindle speed down to the point where you have no effective power left.
Ok then, why?
1. A treadmill motor and controller is nearly free. Depending on some details, actually free.
B. Installed in a headstock as I suggest it will increase max spindle RPM to over 9000. Within some range of spindle speed and loading it would outperform a 1 1/8 HP motor.
III. It can also slow spindle speed down to less than 100 RPM, albeit with a corresponding loss of power.
𐤃. The direction of rotation can be reversed.
rpd
This does interest me, but there are a lot of projects that need doing first. Perhaps next year when i semi-retire.
There is group on Facebook that focuses on this exact subject that you may find of interest.
https://www.facebook.com/groups/shopsmithdigital/about
edma194
I've managed to avoid Facebook so far, and much to my disappointment they aren't even close to collapsing the way their predecessors did. I may have to admit defeat, give up a another piece of my soul, and join the crowd.
My recent problem finally gave me the time to look at these DC motor conversions and the many questions I had previously were easy to answer. If I join Facebook and looked there I'd probably find even more useful information. The main problem with the simple DC motor installations is the simple voltage based speed control for the motors. There may be ways to maintain higher torque from the motors at lower speeds. This is most important for the low end of the speed range. Increasing spindle speed over 9000 RPM at full power is competitive with a PowerPro but in fact there isn't that much need for that kind of high speed apart from routing. At the low end the torque can be very important for operations like drilling with Forstner bits, turning pieces with a wide diameter, and in my case I'm interested in working metal which needs low speeds for milling and turning.
Anyway, my interest is nothing but interest now, I'm way behind on so many things and I doubt even a year from now I could find enough time to do anything like this even if I'm back on my feet and doing things soon. But for the time being it is theoretically interesting.
edma194
Going further with this requires looking into more complicated means of controlling motor speed. I'm looking at PWM (Pulse Width Modification) controllers intended to do this but I have a new question to resolve there, why are the available units so limited in power? These motors are likely to consume the 1800 watts available from a common 120V AC outlet converted to something around 120V DC, it is rectified AC passed through a choke, so averaging something under 120 volts. The common controllers operate at lower voltages, or when they can tolerate higher voltages then less than the potential 15 amps of current consumptions. Basic circuit designs for PWM controllers are common, relying on a MOSFET for switching, and I know as current and voltage requirements increase it is more difficult to implement the simple designs. My electronics background is insufficient to customize such a circuit, I'm just a digital logic guy, this kind of stuff is beyond my experience.
bill50cal
I would never think of trying to convert a shopsmith to a metal lathe. if you have spent any time on a metal lathe you will soon find out the shopsmith is not near strong enough for the forces put into the tool holder and that is just a start as to why i would not do it.
A 120v full wave rectifier will create voltage close to 170v.
Pulse Width Modulation requires rapid switching response at high currents and typically higher voltages.
Components to do that are $$$$$.
RFGuy
I do wonder if these DC motor conversions are practical. I read the FB Shopsmith DC motor conversion group with great interest a year or two ago and there was some great information there. However, I am not sure if these are one-off demonstrations meant to grab online attention, or if the owners are using them to do actual work on a regular basis, e.g. how well do they work in tablesaw mode, lathe operation, drilling or powering SPT's? I don't think I have seen one yet that fits nicely inside the headstock, with the cover on. Also as has been pointed out, perhaps the motor controllers don't work adequately across the entire speed range. IF you have to build your own motor controllers, by the time you buy all the components and print your own PCB you'll be out at least a couple hundred bucks easy (likely even more). Even if you get a treadmill motor for free, is it worth it to spend this much on a science project? Guess it depends on your motivations and what you are looking to get out of it. I contemplated giving it a go before, i.e. to make my own PowerPro on the cheap, but in the end decided it wasn't worth my time especially when you can buy the DVR motor and controller off Amazon for around $500.
rpd
The conversion uses the PWM controller board out of the donor treadmill. This is a YouTube video by Norman Harrison who an admin on the FB group,
He has a newer version that has a smaller control panel, but that video isn't on YouTube.
https://www.youtube.com/watch?v=QbrjPOZqHPI
RFGuy
I agree, often these conversions reuse the existing PWM controller that came with the treadmill. Ed was asking about making his own PWM controller which is what I was responding to before. I have seen this guy from the YouTube video on the FB group before, but my question is whether he is using it to actually make sawdust with it? Or is he only using it to demonstrate his ability to put a treadmill motor in the existing headstock. Has anyone confirmed that using one of these is better than the stock headstock? Is it comparable to a PowerPro? I would be curious to find out if anyone has done one of these treadmill DC motor conversions and showed it ripping through some 8/4 hardwood. It still seems like kind of a science project for science project sake to me so far...
edma194
So you guys have looked at this. I'm tempted to join Facebook and see what is over there.
It's an interesting concept but there are just more questions around every corner. The link from Ron up above is something I've seen before. There isn't much detail there on how he did it. How did he mount the motor and mate it to the shaft for the lower sheave? And while he has an impressive looking control display, it's driven by software, and a complication that's not really necessary for me. I believe I've seen a video where he has the reduced the size of the controller but even less detail was shown there.
So far I'm not getting a good idea of how effective these motors are in a Shopsmith headstock. I've seen videos of several metal lathe conversions that seemed to satisfy their creators, but I I think they were replacing smaller motors. How do these motors perform under full load? Are there overheating problems? There may be a lot of specific applications that could do fine with a highly affordable DC motor, but the Shopsmith is not a simple application, it has to perform in numerous modes with varying conditions.
edma194
I agree with you. I threw lathe into the mix for no particular reason. I actually have a mini-lathe but never used it. The most I've done in metal turning is use a grindstone to turn a motor shaft down by 1/16" while it ran. I do want to do some small scale milling, but I think the speed reducer should be sufficient for my needs.
RFGuy
I revisited the Shopsmith Digital Motor Conversions group to review some of the past posts out of curiosity. The guy in that video also has a PowerPro 520, so I don't know what applications he uses the treadmill DC motor powered Mark V for; maybe he only uses it for sanding? No one seems to talk about what they are doing with them after the conversion, or how the performance compares to a stock headstock. A few comments confirmed that torque at low speed range is a problem, but that is why they try to find as big of a DC motor as they can. Some even started looking for motors larger than 2.5HP to mitigate the low speed torque problem. He used the original motor mount holes in the motor pan and created a pivot on one side with bolts to apply tension on the other. Another guy in the group welded a mount to the motor pan. Some reuse the sheaves for speed control, but the guy in the video bypassed them and made his own touchscreen LCD control with custom SW in Python. Supposedly the files section in that FB group have more details both on the electronics and the motor mounting that some of them did.
edma194
One of the things I'd say is a clear advantage of a DC conversion is a reversible motor. But I've been studying this thread:
G.E. Motor Reversing and it looks quite feasible to add reverse operation. I think if I read that thread over carefully 10 more times I'd understand it well enough to pay a motor shop to do it for me.
Other than locating and separating the start winding, it is merely a matter of reversing the start winding polarity.
edma194
I'm sure it's just that simple. But for now it looks like this blackboard from
The Day the Earth Stood Still to me.
Looks like some stuff I was exposed to back in college.
RFGuy
The 1951 movie or the 2008 remake? I really enjoyed the 2008 movie, but had to go to your link to remember the scene. Below is an explanation of where the equations came from...
Excerpt from: https://www.quora.com/What-was-the-math-problem-in-The-Day-the-Earth-Stood-Still
"The scene in the
1951 movie took place in the home of Professor Barnhardt, a character who was modelled after Albert Einstein. Barnhardt had a blackboard that
contained equations from Einstein's theory of gravity. The alien changed some of the equations to explain how his star ship could travel between the planets.
The
2008 remake of "The Day the Earth Stood Still" contains equations from a paper published by William Hiscock and his graduate student Hector Calderon. Hiscock is director of NASA's Montana Space Grant Consortium. Calderon is visiting assistant professor of physics at Carleton College in Northfield, Minnesota.
The new movie needed to update the equations so they represented the cutting edge of knowledge in 2008 and not Einstein's equations from 60 years earlier. To find such equations, Seth Shostak, senior astronomer at the SETI Institute and a scientific consultant for the movie, contacted Calderon and Hiscock. Shostak said the new script mentions the "Big Rip" possibility in General Relativity, and that led him to read their paper about it.
The Big Rip refers to the possibility that galaxies, stars, planets and atoms would be ripped apart and their parts accelerate away from each other at ever-increasing speeds due to the "dark energy" in the universe."
DLB
Even easier on your PowerPro. ;) IIRC I read that the start winding connections are not accessible on all motors (Emerson?). I'm sure that depends a little on one's definition of accessible...
edma194
That's the best DC motor conversion available for the Shopsmith. You may have noticed it's a bit pricey though. A PowerPro upgrade kit cost me more than all the used Shopsmiths I've obtained.
edma194
Up to this point in the story I had only looked at simple voltage controllers for the motors. These will produce maximum power at maximum speed. What the maximum speed is as a practical matter is unknown. I think without additional cooling running them at 100+ volts will overheat the motor, and I don't think it's designed for that kind of duty at all.
Summing up, the use of treadmill motor with simple voltage control in a Shopsmith has limited appeal. It will allow higher top speeds with possibly more power, but somewhere below 1500RPM power is lost rapidly when reducing spindle speed. At the high end there are questions about the duty cycle, heat production, and life of the motor.
A possible compromise is to limit the voltage to around 50% so the motor tops at 3450RPM like a Shopsmith motor. This makes it a cheap motor replacement, certainly with diminished performance overall. At least in this derated mode the motor is unlikely to overheat or burn out it's bearings rapidly. I don't think in this mode the motor would keep up with 1-1/8 AC induction motor normally found in Shopsmiths when heavily loaded though. The result will be a low performing Shopsmith, I suppose still an option if you can't afford to replace a burned out AC motor.
As another option, if a treadmill motor was installed with another reduction step of approximately 2:1 so the Shopsmith speed controller is being run at about 3450 RPM at with the motor at full power there could be increased power performance across the range of Shopsmith speeds and the ability to further reduce speed with voltage control, albeit while sacrificing power. I don't know if there's room in the headstock for another step down pulley. The motors typically have 1" Poly-V type multi-grooved pulley. I suppose this could be positioned fairly close to a 2" pulley, no idea what the minimum belt length available is. It certainly adds another level of complexity.
In general, the use of treadmill motor with simple voltage control in a multi-purpose application like the Shopsmith will likely lead to disappointment. DC motors don't perform the same way as AC synchronous motors and really aren't designed for this purpose. Still, the low price of the motor, often $0, gives it some appeal.
OTOH a treadmill motor could be a fine motor replacement in tools where variable speed is not needed, or only a limited speed range is needed.
