Log Jig or Tool
mgdesigns
Post by mgdesigns »
Take a photo and post it so we all can learn from what you've come up with. I would think that as a horizontal boring machine, the SS could be used with an auger (short to start) and add extensions as you progress through the log. The clamp could be a simple v-grooved block of wood and a couple of c-clamps to hold it down.
Hand Engraver of Metals; Maker of Exquisite Kindling; 1955 Greenie Mark V (NOW with a 1989 Headstock); Magna Band Saw; Magna 4" Jointer; Miscellaneous Craftsman & Porter-Cable electric woodworking tools.
3D CADCAM Designs - Gemstone Facetor
lmccown wrote:I am trying to build a boring jig for an aspen log lamp about 5" in diameter and 20 " long. Something that will keep it from moving while I use the Shopsmith to bore vertically. Is there a tool or does someone have a jig they use. The jig I am trying to build will act as a sled so both the head stock and the jig can move to accommodate different size logs. I am using a 3/8 14" bit. Lonnie
Here's what I did for a pepper mil that is 20" long. Drilled half way from each end to get the holes to come out in both centers. In your lamp, the holes don't have to exactly match - just enough to run a power cord through. Used the lathe with a chuck and a Forster bit with two 6" extensions.
[ATTACH]16840[/ATTACH]
[ATTACH]16841[/ATTACH]
Another way to deal with that problem is to saw the long cylinder in half and rout a half hole in each side before gluing together.
lmccown
Post by lmccown »
This looks like the way to do it. Thanks and those are awesome pictures. Lonnie
mhebb1
Log turning? or lamp chord bore
Post by mhebb1 »
I bored out a cup center to about 3/8" , chucked up my lamp stock between centers and ran a lamp auger up the middle.
I thought your title meant something like this. Hope the photo comes thru.
