Incrafence with Routing System
SDSSmith
Post by SDSSmith »
[quote="wgander"]Rob,
There must be different tables.
I have a pair of mounting spots on the rear of the table that I marked for the Incrafence. I don't know where I got the instructions to use those holes. Not that it matters, while those holes keep the fence parallel to the long surface of the table, the router bit cutout in the fence is nowhere near the router bit.
I found another set of holes near the top right corner that align the Incrafence with the router. Unfortunately, the first template I was going to use required the Incrajig to be extended almost all the way, which is close to 3" past the router bit. I'll have to mount the Incrajig to a board that can use those holes or be clamped to the work table.
The weather's been hot for over a week: glad we air conditioned the place a couple of years ago. I miss SD, but we live in a condo there]For grins, here are a few shots of the jig and the holes. I temporarily mounted the jig with the thumb screws used to hold the fence. Here is the jig mounted on the right side of the table:
[ATTACH]18016[/ATTACH]
Here a 3/4" bit centered in the fence:
[ATTACH]18015[/ATTACH]
Here is the mirror image set of holes on the left side of the router table:
[ATTACH]18017[/ATTACH]
There is plenty of adjustment to allow centering the fence. I wonder if you have one of the earlier tables. I know that my documentation speaks to a number of upgrades that included the table.
incra fence.jpg (84.47 KiB) Viewed 825 times
incra mount.jpg (84.55 KiB) Viewed 822 times
incra router table left.jpg (73.23 KiB) Viewed 827 times
Rob in San Diego
If you're interested I have a collection of photos of the Over Arm Router here:
http://s589.photobucket.com/albums/ss33 ... 1QQtppZZ24
