It be a good idea to check the top width of the motor belt occasionally. It starts out slightly wider than a half inch. As it wears, it gets narrower and narrower. When extremely worn, it can slip down too far between the sheaves and 'get stuck/jammed'. This is more likely to happen at high rpm
(idler pulley), but can also happen at very slow speeds(motor pulley). Rubber rubbing on metal indicates a slipping belt on pulley.
It takes a long time or a lot of slipping to wear it down to that point(all else being 'normal').
Motor humming indicates a stalled drive train, or start circuit problems if the drive train is ok.
Glad it be 'fixed'!!!
Headstock won't run
timdgarry wrote:What do you mean by a Harbor Freight Link Belt?
http://www.harborfreight.com/catalogsearch/result?q=link%20belt
Link Belt
As always, thanks for the wealth of info.
2 Mark V Greenie, Mark V 500, Mark V 510, 3 Mark V 520, Bandsaw, Belt Sander, Jointer, Mortise, Router, Molder, Shaper, Planer, Jig Saw and looking.
