PowerPro keeps tripping breaker and arcing at plug
So how did your wires get out from under the sleeve and into the gears(and untwisted to boot)?
I think some insulating tubing would be appropriate there.;)(over both wires twisted together).
greasetattoo wrote:OK everyone, fixed the problem...
I am going to run them a different way rather then around the Quill assembly.
Whew.....
Thanks for all the help!
If you do the upgrade, make sure and run your wires so nothing touches them!
The re-routing should solve your problem:D . Notice in the video http://www.shopsmith.com/shopsmithpowerpro/pp_diy.htm (1:32 to 1:45) those two wires never do touch the quill parts. Also that clip is a big help, if one is available.
