For Jointech users
SDSSmith wrote:Here are pictures of one of the newer style inserts that I received from Jointech.
[ATTACH]22741[/ATTACH]
[ATTACH]22742[/ATTACH]
The dimensions of the body are 2" x 4-1/2" x 3/4" and the pins appear to be a fat 1/2" in diameter.
Hi,
I received a set of the black ones as well, they did not fit. Have you tried yours?
At a later point they found a supplier and they sent me replacements for the non-fitting black ones.
I liked the idea of using a stepped dowel for our hand built design, be fun to turn on the lathe too.
SDSSmith
Post by SDSSmith »
reible wrote:Hi,
I have tried them and they seem to fit fine. To be honest, I have not used them with a router bit. As I recall when I received my Sawtrain at the end of 2008, the inserts were not with it. They were shipped early in 2009.
Do you remember what the problem with the fit was, Ed? Maybe there is something that I am missing.
Rob in San Diego
SDSSmith wrote:I have tried them and they seem to fit fine. To be honest, I have not used them with a router bit. As I recall when I received my Sawtrain at the end of 2008, the inserts were not with it. They were shipped early in 2009.
The pins were to tight. If you got them in then getting them back out was an even bigger issue. The pins would pull back out of the block....
I had been in contact with them and he shipped me out a set just "after they got them working" so he was quite surprised by my call saying they didn't fit. They were hand making them at their shop and my guess was lack of any quality control on what was being sent out.
I still have them packed away and I think I could fix them if push came to shove and I never did use them for any routing.
If memory serves me it came with yellow colored inserts, at another point I got a batch that were gray and another group that were orange.... If I can I'll move the stuff from in front of box tomorrow and see what I have in storage.
SDSSmith
Post by SDSSmith »
reible wrote:The pins were to tight. If you got them in then getting them back out was an even bigger issue. The pins would pull back out of the block....
On your black inserts, were the pins separate pieces inserted into the blocks?
My black inserts are made from a solid piece of plastic. They slide easily into the fence.
Rob in San Diego
SDSSmith wrote:On your black inserts, were the pins separate pieces inserted into the blocks?
Yes the pins were removable. I'll see if I can get some pictures tomorrow.
Here it is tomorrow.
Here it is a picture:
[ATTACH]22769[/ATTACH]
The yellow one pictured I have labeled as original so that is the color of the first batch I got. I have that as a plain insert and don't plan to cut it up. The other batches I can't remember the order of, but I do know one of them was before the black ones and other was after.
You can see that on mine the plugs pull out. Didn't know they made some one piece blocks....
It occurred to me that I most likely have one installed in the fence, forgot to see if that is a cut one or not, might mean I have yet another one that I could cut up for routing when needed.
SDSSmith
Post by SDSSmith »
reible wrote:Here it is tomorrow.
Imagine my embarrassment :o, my plugs pull out also. After looking at your picture, I took a pair of pliers and gently removed one.:eek:
I only have the 6 black inserts, but feel that making them in a similar fashion out of wood should not be a real stretch. Gene, if you would like to use one of my inserts as a sample, let me know.
I also like the sacrificial fence halves approach. It certainly would be easier than making the inserts.
Rob in San Diego
Gene Howe
Post by Gene Howe »
SDSSmith wrote:Imagine my embarrassment :o, my plugs pull out also. After looking at your picture, I took a pair of pliers and gently removed one.:eek:
Thanks for the offer, Ed. I think I can just use the one's I have for a model. After seeing the black one, it doesn't look too difficult.
As to your final comment about the sacrificial halves; one could, but where's the fun it that?:D
Gene
SDSSmith
Post by SDSSmith »
[quote="Gene Howe"]Thanks for the offer, Ed. I think I can just use the one's I have for a model. After seeing the black one, it doesn't look too difficult.
As to your final comment about the sacrificial halves]The name is Rob.;)
Rob in San Diego
Gene Howe
Post by Gene Howe »
Ooops!!
Sorry Rob. :( :confused:
Gene
