Drive center sourcing
brad_nalor
I realize this is a month old thread but thought it appropriate to share about centers (rotating or not). Even though the SS accepts centers with a MT2, there is an important difference in the angle and type of center point. For metal working, it often has a more narrow acute angle vs. one for woodworking. Additionally and most important, a woodworking center has an outer cup. You don't want to use a metal turning center for wood as it easily splits it. The center for wood version with cup helps prevent splitting.
Brad, the drive center has to mount on the spindle, and requires a 5/8ths hole with a set screw.
It is only the tailstock that will mount a #2 Morse (MT2) taper. Here a live (bearing) center is better, in most cases, than a dead (you'l need to lubricate that end of the spindle) center.
I've used both types of tailstock centers, and the live center has always been my choice.
steve
steve
brad_nalor
Steve- I realize that and was only referring to the tailstock centers. Agree with you on a live rotating center but would not recommend one designed for metal use on wood stock.skou wrote:Brad, the drive center has to mount on the spindle, and requires a 5/8ths hole with a set screw.
steve
Wood version (notice the cup which prevents end split or the stock from gradual loosening while turning).
For metal (a wedge / point without an outer cup)
- terrydowning
I have a 60 degree center (I use it for pens) since I'm cheap, I made a cup to attach over the point and work as a cup center.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
For those a bit less frugal
, PSI sells a cup adapter for the metalworking live center. http://www.pennstateind.com/store/LCENLTC.html.
Ken
Ken
Ken
Ken
I have one of these and it works very well. It keeps my live center from becoming a splitting wedge.kenbu wrote:For those a bit less frugal, PSI sells a cup adapter for the metalworking live center. http://www.pennstateind.com/store/LCENLTC.html.
Ken
Live Centers with Adjustment Wheel
For many non-SS lathes, the live center is a device that with a turn wheel that allows for very good seating of the wood object to be turned. Does anyone know if there is such a thing made for a ShopSmith.
- Slide1.JPG (21.21 KiB) Viewed 7110 times
The SS quill provides the same function at the drive end.c2h6o wrote:For many non-SS lathes, the live center is a device that with a turn wheel that allows for very good seating of the wood object to be turned. Does anyone know if there is such a thing made for a ShopSmith.
