Wood Burls
The burls I have are in the woods and no open ground anywhere within a couple miles. These are up in the tree and vary in size and look like the one in the vid. that was on You Tube. Thanks for posting that. When the weather straightens out I will take the saw and snowmobile and cut one out as I can use the rest of the tree for firewood. There is one area in the woods that every tree has one on it and they are all cherry trees 6 to 8 inch dia. The burls re different sizes and there are a couple that looks to be about 2 foot long. If I can find one small enough I will saw into it with my bandsaw and see what it is like. My grand daughter wants a jewlery box and this may be a good use for some of it
- joshh
Oh! I think I phrased my statement wrong. Wood and sand can show up on xray but we have to lower the energy to a level not normally used in medicine.Ed in Tampa wrote:But I believe sand does and from what I remember they provided an outline drawing and if you had little specks like little stars seemingly floating around in there the piece had a problem.
- 1986 Mark V 500 Mini
- 1985 Mark V 510 with reversible motor, bandsaw, jointer, and double-tilt.
I offer quality motor reversal, rebuilding, and rewiring. Contact me at HarbourTools@live.com
- Ed in Tampa
sawmill wrote:The burls I have are in the woods and no open ground anywhere within a couple miles. These are up in the tree and vary in size and look like the one in the vid. that was on You Tube. Thanks for posting that. When the weather straightens out I will take the saw and snowmobile and cut one out as I can use the rest of the tree for firewood. There is one area in the woods that every tree has one on it and they are all cherry trees 6 to 8 inch dia. The burls re different sizes and there are a couple that looks to be about 2 foot long. If I can find one small enough I will saw into it with my bandsaw and see what it is like. My grand daughter wants a jewlery box and this may be a good use for some of it
My guess is what you are seeing is self repair from a limb falling off or an infestation by a bug. In both cases I think you will find rotted wood within the burl. I will be real interested to know what you find so please let us know.
Burl that I'm familiar with (those used in pipe making) they were formed in the root or higher up on the tree because of some external pressure (such as another tree, a vine, or something that bent the wood)
Ed in Tampa
Stay out of trouble!
These trees are in an area that I had logged off 25 years ago and at that time they were probably 1/2 dia. What I found odd id that they are all n the same area. I am wondering about rot myself and I think maybe had bug or wood pecker damage at some time. We do have alot of pilated wood peckers and they like the worms that get on them. It is a really good area for mushroomsEd in Tampa wrote:My guess is what you are seeing is self repair from a limb falling off or an infestation by a bug. In both cases I think you will find rotted wood within the burl. I will be real interested to know what you find so please let us know.
