Cold Weather
WmZiggy
Post by WmZiggy »
cantputt wrote: Well, yes it sure is, pretty cold right now up her in Michigan. Is this going to be a problem? Never dreamed that could be a problem. If this is a summer only tool it probably is going back on Craigslist.
Cantputt, I have a really good friend in Bismarck, ND. In 2001 post 9/11 after we were activated (Air National Guard) we also got enrolled in Air War College. Anyone who has spent a year doing that will tell you it's a bonding experience and we both went on to make full colonel when it was all said and done, pinning on the same day. In any event, I digress only to make the point that we are very close friends. She loved my SS and so got herself a 520 new after she retired from the military. She had the same experience as you in her garage.
This past August I helped her and her husband raise the roof on her 20x20 heated garage addition and designated shop. Look at the positive side, here is your opportunity to get that heated garage you always wanted.:D
WmZiggy
williamz@aol.com
cantputt
Post by cantputt »
wa2crk wrote:Do NOT continue to try to start the motor if it hust hums. Doing so WILL burn out the motor windings. The belts may be stuck in the sheaves or the start switch inside the motor is clogged with the debris.
Clean the interior of the headstock with a vacuum and or some compressed air to clean out any sawdust.
Then try to start it again and if it hums turn it off IMMEDIATELY.
You may want to try installing the sanding disc on the main spindle and the turn the disc by hand. If it turns easily then the mechanical stuff is most likely OK. If you still have problems check back here for more info.
And bye the way, WELCOME!!
Thanks, I will open things up and get a better look tonight. I had a bumpy, snowy 1 1/2 hour transport so maybe something happened. I did have it tied down very well in an enclosed trailer.
cantputt
Post by cantputt »
WmZiggy wrote:Cantputt, I have a really good friend in Bismarck, ND. In 2001 post 9/11 after we were activated (Air National Guard) we also got enrolled in Air War College. Anyone who has spent a year doing that will tell you it's a bonding experience and we both went on to make full colonel when it was all said and done, pinning on the same day. In any event, I digress only to make the point that we are very close friends. She loved my SS and so got herself a 520 new after she retired from the military. She had the same experience as you in her garage.
LOL, that thought did cross my mind.
cantputt
Post by cantputt »
Broke out the old torpedo heater and warmed up the garage while I did my snowblowing.. I used the walls from an EZ Up to close things off a little. Wam bam the old SS fired right up. So glad I have that issue behind me.
oldc6
The Weather
Post by oldc6 »
A little shot of the weather today in central Minnesota.
been blowing 40 to 50 mph since noon today.
Luckily we do not have a lot of snow on the ground.
It is whipping what we do have into zero visibility.....
see picture. -22 degrees for tonight...........
oldc6
the picture
Post by oldc6 »
did not attach will try again.:confused: :confused: :confused: :confused: :confused: [ATTACH]23869[/ATTACH]
[ATTACH]23870[/ATTACH]
cantputt
Post by cantputt »
Ya, that's coming our way. Snowing hard right now and we have plenty on the ground. Tomorrow is going to be nasty cold and blowing.
cantputt wrote:Ya, that's coming our way. Snowing hard right now and we have plenty on the ground. Tomorrow is going to be nasty cold and blowing.
Where yat?????
Mike907
Post by Mike907 »
Thank goodness for global warming! We're above freezing here in Anchorage. Which is good because my garage/shop heater quit working a week ago.
cantputt
Post by cantputt »
JPG40504 wrote:Where yat?????
Western Michigan. We get constant lake effect snow from the cold air coming across the warmer water of Lake Michigan. My house is on the eastern edge of the Lake effect so I am not as bad as people along the lake shore. Right now we are deep in snow. South of us they are ticketing anybody driving today it is so bad.
