dusty wrote:There is no comfort in this at all but if I put a straight edge against my jointer fence I have a gap that begins about at the counter head and extends toward the out feed end for about 3" or 4".
I never noticed this before.
I finally got around to measuring the flatness of my jointer fence. My surface plate is only 12" long, so for a reference I checked my 24" Starrett straightedge against a 24" Lufkin straightedge. There was no discernable gap between any two edges, so I'm guessing that both were straight to maybe 0.001"
Then I placed the Starrett straightedge diagonally across the fence, giving the maximum gap. Using feeler gauges, I measured a maximum concavity of 0.006". It looks worse than it sounds, but I do believe that the twist in the fence was affecting my ability to joint edges precisely to 90 degrees.
Most any machine tool should hold better tolerances than that, so my hunch is that my fence was machined while the cast iron was still "green", and then it warped as the iron aged. That, BTW, is one of the biggest quality problems with cheap Asian machine tools.
Then I called Shopsmith customer service to ask about my flatness-challenged jointer fence. I talked with an extremely knowledge able and helpful lady -- Linda, I believe. It took her less than a minute to find Shopsmith's spec for acceptable flatness on a jointer fence. The spec, unfortunately, is 0.015" max.
So for a fix, I've decided to make an auxiliary fence from an appropriately flat material. I'll use hot glue to make instant custom shims between the auxiliary fence and the jointer fence. These will be permanently bonded to the auxiliary fence, so that the jointer fence doesn't warp it when the mounting bolts are tightened.
Some extra height on the auxiliary fence will also be a plus.
