Bandsaw - Tilt Lock Assembly
I was on the phone with Jan at SS for almost an hour this afternoon, which included time for her to confer with people in the shop. I have ordered the Trunnion Supports and new bolts to solve my problem. I will update here after the parts are installed.
Brian
Mark V-500 Purchased New In 1980, SS Bandsaw (free), SS Jointer, SS 6x48 Belt Sander (free), SS Storage Station (free), Powermatic 64A Table Saw, Powermatic 1140F Drill Press, Delta 46-460 Midi-Lathe, Delta Scrollsaw, Bosch 12" Dual Compound Miter Saw, MLCS Router Table w/Bosch Router, Penn State dust collector.
If you don't mind, after your sure it fits/works could you list the part numbers and quantities of what you got??? Pictures would be great too.
S Brian wrote:I was on the phone with Jan at SS for almost an hour this afternoon, which included time for her to confer with people in the shop. I have ordered the Trunnion Supports and new bolts to solve my problem. I will update here after the parts are installed.
I will do that.
Brian
The plastic parts look none the worse for wear. However, I tilt the bandsaw table very little so these parts have not been exposed to any significant durability testing.reible wrote:Glad you guys were able to dig out that information.
Dusty have you looked at those plastic parts again to see if they are still intact? My saw is too old for that change but I was wonder how this set up holds up.
That is good news Dusty, I worry about changes to plastic parts. Your conformation helps with that.
I don't tilt my saw a lot either but it does happen, so while at lower risk of these parts failing because of this would be the same in my case.
dusty wrote:The plastic parts look none the worse for wear. However, I tilt the bandsaw table very little so these parts have not been exposed to any significant durability testing.
Don't let the Gorilla help with set up!reible wrote:That is good news Dusty, I worry about changes to plastic parts. Your conformation helps with that.
Re: Bandsaw - Tilt Lock Assembly
This has been a long time without response and I apologize for that.
The plastic parts are doing well.
