Ripping a 12" by 12" 2 foot long block
JPG40504 wrote:Who said it was walnut???
See post #7
WmZiggy
Post by WmZiggy »
Score it on the table saw and then rip it with your handsaw. Be sure your handsaw is a rip saw and the teeth are sharp. The kerf from your table saw cut will help you stay straight. You should only have about a 6" thickness to hand rip if you kerf it 3" to a side. Then plane the sawn surface with a #5 Jack or #4 Smooth plane to remove the saw marks.
WmZiggy
williamz@aol.com
fredsheldon
Post by fredsheldon »
WmZiggy wrote:Score it on the table saw and then rip it with your handsaw. Be sure your handsaw is a rip saw and the teeth are sharp. The kerf from your table saw cut will help you stay straight. You should only have about a 6" thickness to hand rip if you kerf it 3" to a side. Then plane the sawn surface with a #5 Jack or #4 Smooth plane to remove the saw marks.
I didn't know if there would be any issues with just running it over my table saw blade part way on both sides then using a handsaw. Do you free hand on a sled it or use the fence?
Fred Sheldon
The Woodlands, Tx
beeg
Post by beeg »
fredsheldon wrote:I didn't know if there would be any issues with just running it over my table saw blade part way on both sides then using a handsaw. Do you free hand on a sled it or use the fence?
I'd just use the fence, so ya get both cuts parallel.
WmZiggy
Post by WmZiggy »
Ditto what beeg says.
WmZiggy
williamz@aol.com
reible wrote:See post #7
Missed that!:o
Also the thread title(ripping).:o:o:o
"free hand"???????????:eek:
terrydowning
Post by terrydowning »
Always use a fence when ripping on a TS. Always use a miter gauge or sled when cross cutting.
Free handing on a table saw is an invitation to injury.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
beeg wrote:Are you really saying it's two foot long, 12" wide and 12" THICK??
Everything is BIG in Texas! Well, almost everything/
fredsheldon
charlese wrote:Everything is BIG in Texas! Well, almost everything/
It was until I cut in down into 12 6"x6"x8" blocks with some left over for later. A friend has a mill and he gave me the block along with some oak logs from which I produced about 30 bowls. It had been sitting in his barn for years.
Fred Sheldon
The Woodlands, Tx
