That is an idea but I have only one of these, the other shopsmiths I've purchased didn't come with one. So for now I don't want to wreck what I have. But I will keep it in mind, thanks.
greitz wrote:Ed- the Shopsmith lathe screw center has a hole that's a little too small for a 3/8" x 16 screw, but maybe you could bore it out a bit?
Some think like this would work but it has to be a 3/8" x 16 tpi. It also has a thread length requirement so it doesn't hit the second plate. I'm also thinking that they are not make with the setscrew being on an angle, a personal requirement that I have.
Thanks for taking the time to find this, who knows if I will ever come to need this size???
I have a pendant that I would like to try and make and it requires that the plate be rotated in addition to being set off-center. If I ever get this to work all will be made clear. At this point it is not even clear to me how this works but once I can play some more I might even figure it out???
terrydowning wrote:I don't get it.
Why are you setting the indexed plates 180 degrees out?
Yes once the 0,0 setting is trued it stays trued as long as it is set at 0,0 or returned to 0,0. This would not be a problem for most turning but once you start indexing things go wrong very quickly.
You can be sure I will let everyone know when this is solved even if I never find out the root cause.
dusty wrote:Ed, I assume you initially trued the block with it attached to the faceplate and the faceplate aligned 0/0. I further assume that if you return to that setup, the vibration goes back to normal.
If that is the case, it seems to me that somehoe the black simply gets off center to the faceplate.
If I go the route of having one built it will be pretty much like what you pictured. I'll most like go this build route as then I can control what it looks like and make it for a shopsmith. Cost might be a factor but then I'm poor anyway so what's the big deal about being a little more so??
SS 500(09/1980), DC3300, jointer, bandsaw, belt sander, Strip Sander, drum sanders,molder, dado, biscuit joiner, universal lathe tool rest, Oneway talon chuck, router bits & chucks and a De Walt 735 planer,a #5,#6, block planes. ALL in a 100 square foot shop. .
This SS version was not unexpected. Ruth and I had discussed this in length earlier this year. I had provided her much shopsmith information but had no idea when the product would be ready. This is truly good news at this point in time as it is clear I need one of these.
I'll be calling her as soon as I finish this post.
BTW this information has been added since I ordered my kit, May 7th.
OK then, I have the mandrel on order from Ruth, should be here Thursday (May 22).
Last night I had contacted Rick over at the penturners.org and he has agreed to make me a version. Mine will be a shopsmith 5/8" mount with angled set screw. Rick has my sketch and I'm sure I will hearing back from him soon.
So I will end up with two ways to go.
I'll be back with more updates as they come in. Now back to gardening.
