OK, what is this?
e.friedl
Post by e.friedl »
Yes it bolts on with separate fasteners onto the mount plate. I'll try to remember a close up of that when I take photos.
e.friedl
lower pulley guard
Post by e.friedl »
here are some photos of the guard
e.friedl
Post by e.friedl »
one more. I'm glad I found it and glad to share the photos
Thank you for the pix.:cool:
You might want to clean the lens.;)
rpd
Post by rpd »
Congratulations on getting the lower belt guard, that is a real score.
The power outlet mounted on the back side of the headstock/motor is a great idea. I had been thinking about mounting an outlet on the bench but this looks like a more elegant solution.
I am curious about the switch on the front side, does it switch the outlets, or switch the motor, or reverse the motor?
You got a couple of other 'extra' goodies - SPT mount and coupler 'hub'.:cool:
"Wild Bad Bob"
Post by "Wild Bad Bob" »
Dang, cant get ANYTHING past JPG!!!!!
e.friedl
a few more comments
Post by e.friedl »
In regard to the outlet on the back of the headstock, the outlets are hot anytime the unit is plugged in. Although it might be nice to turned on and off with the headstock if you wanted to plug a shopvac to run with the headstock. Now for JPG's comment, when trying the cover I mounted on my old unit not the "new" one. I bought the pulley with the coupling hub and the SPT mount. I did hit the bonus pick with my purchase but those two items
e.friedl wrote:In regard to the outlet on the back of the headstock, the outlets are hot anytime the unit is plugged in. Although it might be nice to turned on and off with the headstock if you wanted to plug a shopvac to run with the headstock. Now for JPG's comment, when trying the cover I mounted on my old unit not the "new" one. I bought the pulley with the coupling hub and the SPT mount. I did hit the bonus pick with my purchase but those two items
Most duplex outlets allow separate connections to each 'outlet'. One could be hot when plugged in and the second hot only when the power switch is on(motor on).
Thought those extra goodies looked very 'new'.;)
