Totaly Ss Addicted!!!!!????
rbursek wrote:Given sufficient time even ye shall unnerstan
The demo last weekend had a lifter on it. Smoother then snood!!!! May get one soon!!!
And 'his' was heavier than thine!
Not only that, he is shorter!
Bet he did not 'demo' the tilt interference 'issue'.:D
algale
Post by algale »
JPG40504 wrote:And 'his' was heavier than thine!
That's the beauty of the Mark 7 double tilt...no more interference (since you have to remove all the SPTs to go vertical).
algale wrote:That's the beauty of the Mark 7 double tilt...no more interference (since you have to remove all the SPTs to go vertical).
I wasn't referring to spt's.;)
And, the 7 lift assist needs be disconnected to tilt left. I am sure much verbage was created as a diversion as he disconnected/connected the lift.
Not to be dissing the 7 or anything else, multi function does involve compromises. The more gizzy whitches are added, the more 'issues' crop up.
algale
Post by algale »
[quote="JPG40504"]I wasn't referring to spt's.]
Oops! Thought you were referring to the aluminum band saw table SNAFU.
algale wrote:Oops! Thought you were referring to the aluminum band saw table SNAFU.
That too!!!!
A while back Reible posted a thread on the problem of cutting a bevel on a wide workpiece using the floating table with the lift assist. The lift assist interferes with the table and headstock thus causing the end casting to interfere with the tilted table and extended floating table which limits the width of the workpiece. None of that happens without the lift assist.
"Wild Bad Bob"
Post by "Wild Bad Bob" »
No he did not mention the interference issue, but with all the discounts he was giving, it may have been the time to buy the lift. Can it be mounted on an ER ball buster???
