Bandsaw bearings
beeg
Post by beeg »
creekrunner wrote:Will these bearings suffice or replace?
I appreciate opinions and suggestions.
David
I'd say replace em all.
billmayo wrote:Please contact me off-line. I have a double bearing package available that works on the early bandsaws with the roller bushings that includes the bolts.
If you need to use it right away, they will suffice, but will likely be noisey.
Longer term - see Bill Mayo's offering.
creekrunner
Post by creekrunner »
Ordered kit and manual.
But meanwhile, I installed the new blade, tensioned it as per instructions and made a couple of sample cuts. It did ok but tracked a little. I had a temp clamped on fence (2x4) and was on my lunch hour so in a bit of a rush.
Saw was noisy also so I will do the upgrade.
Thanks to everyone for the help and advice.
David
creekrunner
How do you imbed the images rather that attach?
David
Resaw4x4 (1).JPG (179.75 KiB) Viewed 4221 times
S Brian
Post by S Brian »
It looks like you should also replace your Cool Blocks -
555374 Bandsaw Cool Blocks Blade Guide.
Last year, I bought Bill Mayo's bearings and bolts and was very pleased with the improvement to my bandsaw.
Brian
Mark V-500 Purchased New In 1980, SS Bandsaw (free), SS Jointer, SS 6x48 Belt Sander (free), SS Storage Station (free), Powermatic 64A Table Saw, Powermatic 1140F Drill Press, Delta 46-460 Midi-Lathe, Delta Scrollsaw, Bosch 12" Dual Compound Miter Saw, MLCS Router Table w/Bosch Router, Penn State dust collector.
db5
Post by db5 »
creekrunner wrote:How do you imbed the images rather that attach?
David
Here's what works for me: After you submit the post click on edit and then on "Advanced" and then the paperclip (looks like a paperclip) at the top. then you can cut (Ctrl C) the post and position it above or below the image.
There are probably easier ways but I haven't found one.
Click in the paper clip to 'attach'. As you apparently are doing.
Return to the 'Reply to Thread' screen and after positioning the cursor where you want the pix to appear, AGAIN click on the paper clip. A drop down menu will appear with a 'manage attachmennts' option, a list of your attachments, and an option to insert ALL attachments. The rest depends upon what you then click on.
You then end up with 'inserted pix'
[ATTACH]26378[/ATTACH]
[ATTACH]26379[/ATTACH]
The pix will not display in the reply screen but will in the preview and after being submitted.
belt cover hole aids assembly.jpg (554.19 KiB) Viewed 4241 times
pp parts.jpg (67.58 KiB) Viewed 4244 times
creekrunner
Pics management
Tryin' to figure this out
A small (2.5x6) piece of old barn wood
[ATTACH]26380[/ATTACH]
Same piece
[ATTACH]26381[/ATTACH]
4x4 treated scrap piece
[ATTACH]26382[/ATTACH]
Resaw4x4 (1).JPG (179.75 KiB) Viewed 4229 times
