Jointer
ERLover
Re: Jointer
John, If I am looking at them right they are like that guy from horse country, warped. When stacked there warpness/offset tension act as a spring?!
WildHorseHans
- Silver Member
Re: Jointer
This may be a two fold problem. I just went out to check the runners and while the tables were apart I turned the depth knob. It is very stiff like the threads are dirty. Looks like I need to run a tap through the knob to chase the threads. We'll see if that helps
Re: Jointer
Pictures PleaseERLover wrote:John, If I am looking at them right they are like that guy from horse country, warped. When stacked there warpness/offset tension act as a spring?!
Re: Jointer
That's what I called them because I don't know what they are really called.dusty wrote:Thank you. I gathered that from the parts list. I need to do some research into "compression washers". To me, they just appeared to be washers of a different size and color than the others. They obviously are more than that.Bruce wrote:I checked my jointer and it would not go past about 3/16. That's enough for my purposes since I've never cut rabbets with my jointer. But I couldn't just leave it in that condition. I disassembled it to check the machined runners for gunk. As the photo shows they weren't gunky, but one of them looks kind of chewed up. A bad casting job perhaps. I ran a flat file along the edges of the raised flats on the right side then waxed the runners and reassembled the jointer. I tightened the nut just until any play was removed from the indeed table. It will now move through the whole range, although it does get a little hard to move past 1/4". Dusty, those stacks of washers are alternating flat and compression washers.
Edit: I'll have to resize the photo and upload it later.
Re: Jointer
Here is the photo I promised in my earlier post in this thread.
- jointer runners
- IMG_2978.jpg (94.83 KiB) Viewed 1386 times
Re: Jointer
Not really. "Spring washers" are used to keep the proper tension between two mating parts, ie. the sliding ways on the SS jointer. A lock washer (split, star etc.) is used to keep a fastener from coming loose due to vibration or other forces.Bruce wrote:That's what I called them because I don't know what they are really called.dusty wrote:Thank you. I gathered that from the parts list. I need to do some research into "compression washers". To me, they just appeared to be washers of a different size and color than the others. They obviously are more than that.Bruce wrote:I checked my jointer and it would not go past about 3/16. That's enough for my purposes since I've never cut rabbets with my jointer. But I couldn't just leave it in that condition. I disassembled it to check the machined runners for gunk. As the photo shows they weren't gunky, but one of them looks kind of chewed up. A bad casting job perhaps. I ran a flat file along the edges of the raised flats on the right side then waxed the runners and reassembled the jointer. I tightened the nut just until any play was removed from the indeed table. It will now move through the whole range, although it does get a little hard to move past 1/4". Dusty, those stacks of washers are alternating flat and compression washers.
Edit: I'll have to resize the photo and upload it later.They are a kind of lock washer, but not a split washer.
Re: Jointer
Thanks for the clarification. I'm not an engineer, so it's nice having a few on the forum to keep us all informed.Not really. "Spring washers" are used to keep the proper tension between two mating parts, ie. the sliding ways on the SS jointer. A lock washer (split, star etc.) is used to keep a fastener from coming loose due to vibration or other forces.
