Table saw enlargement?
Re: Table saw enlargement?
that does looks like another good alternative to the rolling pin type. IMHO anyone that would sell the rolling pin type as a saw out feed needs there head examined.
What's so bad about rolling pin type stands? I borrowed some from a friend when I was dealing with some lengthy stock and found them quite helpful.bill50cal wrote:that does looks like another good alternative to the rolling pin type. IMHO anyone that would sell the rolling pin type as a saw out feed needs there head examined.
id like to increase the size of the table and have it be more functional . It seems to me that it is very difficult to dado long material. Shelves and cabinets ...
Frankly it just feels awkward and even risky with the simple table as is. Space is limmited and I'd like to put this machine to work and buy something expensive. I suppose I'll do this type of dado work with a router and buy attachment so as to feel more comfortable. Great suggestions and help, thanks
Sorry, I meant I really don't want to buy an expensive table saw, thanks
You are right to worry about working with long material without adequate support, particularly on the outfeed side. If you are primarily cutting with the table flat (as opposed to tilted for bevels) it is easy and relatively inexpensive to set up some temporary outfeed stands, some of which are linked to in reible's links, above. If you need to cut bevels on long pieces with the tilted table, outfeed support gets more complicated. There are some solutions posted by members. Search "outfeed" on the Forum and you will find a bunch of ideas.Gino wrote:id like to increase the size of the table and have it be more functional . It seems to me that it is very difficult to dado long material. Shelves and cabinets ...
i am glad it worked out for you BUT as I stated earlier if not setup right they WILL cause the wood to drift right or left which can cause a dangeris situation.
- Ed in Tampa
Take a serious look at a guided saw system. They are made by Festool ( most expensive) Dewalt, Makita, and Grizzly. Also Eurekazone sells adapter plates and guides that can be used with just about any saw.Gino wrote:Sorry, I meant I really don't want to buy an expensive table saw, thanks
Guided Saw System is second only to a commercial panel saw for breaking down sheet stock 4x8 plywood. Plus it is far safer and easier on your back than trying to manhandle a 4x8.
Most commercial shops have switched to or are in the process of switching to panel saws or guided tool systems. They are being pushed big time by their insurance and safety regulations.
And this is why you would recommend one for a hobby shop???Ed in Tampa wrote:Take a serious look at a guided saw system. They are made by Festool ( most expensive) Dewalt, Makita, and Grizzly. Also Eurekazone sells adapter plates and guides that can be used with just about any saw.Gino wrote:Sorry, I meant I really don't want to buy an expensive table saw, thanks
This will work and can be tilted. However, it is not real cheap. Watch eBay for the extra floating tables and tubes at a good price.Gino wrote:id like to increase the size of the table and have it be more functional . It seems to me that it is very difficult to dado long material. Shelves and cabinets ...
- DSCF0453 (640x480).jpg (92.23 KiB) Viewed 3637 times
This works very well BUT we don't know which model Shopsmith Gino has as a base. He is attempting to eliminate issues caused by a "small table surface". This makes me ASSUME he has a 500. This solution would then not be ideal.
