I hate when this happens
john
Re: I hate when this happens
Post by john »
Ed:
I'd work with the wood I have on hand nobody would notice. Of course now you have told us all but we will keep quiet.
Chuck:
Nice work around! Nice bench too!..
Have fun
John
My sketchup skills are a little rusty. I got a full size bench drawn with all the angles and what not figured out. It wasn't that hard but I went off on a tangent and got myself into a never never land. Take two was much better.
I think I will go with the 30" top and then reduce the stretcher so the over hang stays the same. I'm also going to shorten it just a bit, maybe an inch or two so it looks lower set.
Its going to be a fun project once the weather warms and I can get started on it.
It is one of those things that I like when I first saw it and knew I wanted to build one right then. I was to be fall project but then things got to busy....... Going to make time for it this spring/summer.
roy_okc
Post by roy_okc »
Here's a great concept for your short board: http://www.finehomebuilding.com/item/22 ... -scrap-bin
Roy
Laser engraver
So while I was at projects today I also went back in to sketch up and used the scaling feature. Using the length of 30" rather then 36" gives you a 30/36 = .8333333333333333 so I went with .833 and it is close enough to work with. I then scaled the height down to as close as I could get it to 17".
That is a pretty slick tool and the first time I've used it. Now I have to disassemble the parts and get the new lengths for a cutting diagram.
Warm but wet week according to the weather person so it could be that I might even cut wood this week. Still a few other things ahead of that project wise but I can always hope.
ScreenHunter_105 Mar. 06 00.10.jpg (26.33 KiB) Viewed 1961 times
I've got a couple of odd dimensions I still have to work out as you can see but I could just work around them, I mean what is a 1/64" anyway for a garden bench.
