WoodshopTips single PDF download
roy_okc
Re: WoodshopTips single PDF download
Post by roy_okc »
Awesome, RJ, thank you very much!
Roy
CNCed G0704 milling machine
Laser engraver
thunderbirdbat
Post by thunderbirdbat »
This is nicely done, thank you. Maybe it could be added to the newbie sticky post in Maintenance for a reference.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
thunderbirdbat wrote:This is nicely done, thank you. Maybe it could be added to the newbie sticky post in Maintenance for a reference.
Or "General Woodworking" forum.
thunderbirdbat
That is true, but there is not a sticky post in General Woodworking while there is in Maintenance & Repair. I figured it would be easier to edit an existing sticky than to create a new one.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
rudy49
Post by rudy49 »
This is great. Thank you very much.
Larry
Admin can make it happen. A post to start it will help. This one is already cluttered.
Dave H. (CO)
Post by Dave H. (CO) »
Thanks, that's fantastic!
lyall
Post by lyall »
here are the ones from 216 to 279. note some at end were not there. Just a very few.
Note it is under 500 KB download, and I was not able to put the index on it , but it does have the thumbnails. On my PC it does show the bookmarks.
I do not know why!
WoodshopTips 2.pdf
(458.52 KiB) Downloaded 1123 times
maybe somebody can add the indexing and repost it.
reubenjames
Post by reubenjames »
Thanks! I'll take care of it tonight.
Alec S.
1985 Mark V upgraded to 520 and Power Pro (SN 000527)
1983 Mark V Shop Deputy (SN 163487)
1982 Mark V headstock (SN 122265)
1949 (?) 10 ER in transition to dedicated drill press (SN 18677)
11" Band Saw (Aluminum Table System upgrade) (SN 34026)
4" Jointer (SN 02-18-98)
6" Belt Sander (SN 19012)
18" Jig Saw (SN 17407)
20" Scroll Saw (SN 010593)
12" Thickness Planer (SN 10406)
Strip Sander (SN pending)
DC3300 Dust Collector (SN 102088)
everettdavis
Post by everettdavis »
Helpful and very thoughtful thing to do.
Thank you!
Everett
